Old 02-09-2008, 01:47 PM   #1
Morpheus2010 is an unknown quantity at this point
Shark 8" problem
i HAVE THE SAME PROBLEM My 8 inch shark screen from gooddeals18. Yesterday the screen just went black while rr was running. The wierd part is that the touchscreen part of it still works. I push where play would be on the screen and the computer responds, next, pause etc etc.
Morpheus2010 is offline   Reply With Quote
Old 02-09-2008, 01:48 PM   #2
Shark 8" problem
Old 02-09-2008, 01:49 PM   #3
Old 02-09-2008, 03:18 PM   #4
bbalazs is an unknown quantity at this point
It is not weird, because that unit is TOTALLY INDEPENDENT, not the part of your monitor (it is just ON the monitor). That is a USB-powered flat mouse
bbalazs is offline   Reply With Quote
Old 02-11-2008, 08:37 PM   #5
so how i can solve the backlight problem?
Old 02-12-2008, 02:40 AM   #6
As the previous poster said (I do not know which topic, because you have invaded all topics with your problem), it can be a connection problem.
Disassemble it, pull out all connectors, wipe and rub with alcohol, push back them.
Regarding the type of the problem, it is possible that the disassembly-assembly could help alone.
If not, follow my advices in other topic (with the original question).
reconnected puter and now audio problem.. NYCdesignkid Car Audio 2 05-31-2006 12:09 AM
gps navilock and com problem lele67 GPS 0 04-01-2006 08:41 PM
Problem with directshow filter and WMP EricE Software & Software Development 0 03-01-2006 11:38 AM
Car Idle - power/amp problem? TheFaze Car Audio 1 12-16-2005 12:10 AM
Lilliput TouchKit problem solved! AAVfReaK LCD/Display 2 10-16-2004 04:51 PM
