Out of range means you have one or more settings beyond what the monitor is capable of displaying.
The usual culprit is the refresh rate, but size can also cause the same behaviour (depends on the monitor).
Hook your puter up to a regular crt monitor and see what it is running. Adjust the settings and try the in dash until you find something that works.
You can start at 800X480 and a refresh around 70-72 hz to start with (that's where my lili likes to be).
Be aware that there are alot of settings in powerstrip you have to get right for a custom resolution to work properly.
If you can't find a rate that works, you may just have to stick with 800x600..........
Leonardo Da Vinci
