Old 02-15-2008, 02:03 AM   #1
canadiandream is on a distinguished road
Touchscreen calibration problems
Hey guys, I am at a lost. Spent the last hour reading threads on this issue...but no luck. I am running a Super 7" monitor. Now I am using the original manufaucturer drivers (also tried 4.0.2.1929 or something like that). The touchscreen is recognized, the problem is when I try to do a 4 point calibration.
I get a white screen with a green X at the lower left, and a timer bar. The problem is the green X does not blink. If I touch it with a finger, or stylus, or hold it down I can never get past the solid green X.
If I do a draw test..all I can get is a yellow line at the very bottom of the screen.
I have removed the screen from its case so I am certain it is not anything pressing on the screen.
Any help is much appreciated.
Thanks.
Okay quick edit. Looking closer at the green X, it blinks from green to red about 2 times. Then the X goes solid green without me ever touching the screen.
The computer is a laptop. Do I need to disable the touchpad built into the laptop?? I tried in device manager, but you can't disable it there.
canadiandream is offline   Reply With Quote
Old 02-15-2008, 03:15 AM   #2
MCT
Banned
MCT is an unknown quantity at this point
Sounds like the front bezel of the monitor is pressing on the touch panel. If this is not the case, you need a new touch screen panel.
MCT is offline   Reply With Quote
Old 02-15-2008, 03:37 AM   #3
Yea, as I mentionned...already tried that. Removed the LCD from the front bezel completly and still happens. Thanks though.
Old 02-15-2008, 11:30 PM   #4
Anyone else guys....I am at a loss..and starting to thing the touchscreen panel is damaged.
Ideas, help are much appreciated.
help with touchscreen calibration chinkst3r Input Devices 1 01-16-2008 09:29 PM
Touchscreen problems :( Ryanmt LCD/Display 4 07-26-2005 12:36 PM
Touchscreen Calibration.. How Long? AJ Quick Input Devices 4 01-04-2004 05:21 PM
problems with digitalww.com touchscreen samc Input Devices 11 04-07-2003 09:09 AM
Weird touchscreen problems claylong LCD/Display 0 02-25-2003 08:46 AM
