Notices
Old 02-23-2008, 10:55 AM   #1
jaymatic21's Avatar
Lilliput screen fro ebay what do u think?
http://cgi.ebay.com/New-Lilliput-7-T...QQcmdZViewItem
The only thing im worried about is the vga connection is this ideal?
http://img215.exs.cx/img215/3613/jay.gif
Either love me or leave me alone
jaymatic21 is offline   Reply With Quote
Old 02-23-2008, 01:36 PM   #2
brucedog's Avatar
I took a few minutes to carefully look over the ebay link that you provided.
From what I can see, this unit is about identical to the Lilli629 that I use in my car.
Same wattage, dimensions, accessories...except that I paid $245 from mp3car strore in early November '07.
I like mine a lot, but my lack of experience didn't prepare me for the fact that the touchscreen overlay is filmy and definitely reduces the quality of screen images. I'm older, and I would prefer clarity...
Yeah, that funky adapter fitting for vga/other inputs is the same as mine. Works ok and not too unwieldy. See my pics; I have goosenect mount, so those extra unused inputs are cable tied, but still visable. Can't bring myself to cut 'em off, as other inputs COULD be used some day.
I found this in the LCD / Display forum:
http://www.gooddeals18.com/product/SHK1040
Check the LCD / Display forum for that one; a lot of responses 'cause it sounds pretty hot. Even if I install my current Lilli in the dbl DIN spot in my dash, I may buy one of those 12" monitors. I like to be able to see and enjoy what's on my screen...
I have only been using my Lilli as a basic screen; never set up the touchscreen part, but I plan to plug USB from my Lilli into front-seat USB hub, then load Lilli touch app - probably tomorrow. I have been using the front end, Street Deck that I bought from mp3car store - and I'm ready to use it in touch mode...
Happy carpc'ing!
brucedog is offline   Reply With Quote
Old 02-23-2008, 02:56 PM   #3
greatwhite's Avatar
That's an eby 701. Search the forums as there are many reviews and comments on it.
It's very popular due to it's bargain basement price.
I have one and it's taken alot of abuse, still works fine.............
VGA connector has never been a problem other than my not having the barrel connection tight enough one time.
Leonardo Da Vinci
greatwhite is offline   Reply With Quote
Old 02-23-2008, 03:54 PM   #4
Raw Wave
HiJackZX1's Avatar
The model shown is the older eby 701. The newer one is brighter.
PLANNING [100%]
CAR PC ITEMS [100%]
INSTALL OF PC [50%]
BUG WORKOUT [90%]
INTERIOR MODS [75%]
BUDGET [380%]
HiJackZX1 Work Log
DodgeTalk
HiJackZX1 is offline   Reply With Quote
Old 02-23-2008, 08:34 PM   #5
jaymatic21's Avatar
brucedog do you have pics of it installed how was the install straight up? any custome mods have to be made to fit it in?
Old 02-23-2008, 08:49 PM   #6
brucedog's Avatar
See where my name and carpc specs are on this reply?
Now, look down below it, and you can see my pictures.
Click on my pictures to view. c,lick on the picture to see enlarged.
A picture is truly worth 1000 words.
Happy CarPC'ing!
Old 02-23-2008, 08:53 PM   #7
brucedog's Avatar
Oh, the gooseneck mount has a tab that slides into the notch on the rear of the Lilli, then can be hand tightened - easy.
I had to put the tab on the gooseneck on my grinding wheel a little bit as it was oversized for Lilli notch - no trouble.
Happy CarPC'ing!
Old 02-24-2008, 01:12 PM   #8
lor109's Avatar
Why is the newer brighter? LED Backlight? Any ideas?
lor109 is offline   Reply With Quote
Old 02-24-2008, 10:40 PM   #9
It is exactly the same as mine.
The box too. When i first received it, after looking on the box, i thought the shop must of gotten the order wrong.
The connections it uses are fine.
Not to sure about much more then that though as i haven't put it in my car as of yet.
hydie is offline   Reply With Quote
Old 02-24-2008, 11:00 PM   #10
Fusion Brain Creator
2k1Toaster's Avatar
I have used this screen for 2 years now. Only thing is I blew up my 800x600 resolution support, and I am not sure how. I am on my second touch overlay. Both things my fault. I have opened the thing up down to the bare LCD panel (not just circuit and LCD block, but I mean taking it apart to the see through glass panel, backlight and so forth, a few times, and put it back together and it works. I dropped a textbook (3 inch thick textbook) right on the LCD and cracked the upper corner, but the pixels all still work except for directly under the crack (didnt leak out everywhere)...
So yeah. I have used and abused this thing and I would buy it again. It was $200 including shipping and customs from Hong Kong when I ordered it 2 years ago.
Old 02-24-2008, 11:05 PM   #11
Raw Wave
HiJackZX1's Avatar
Yes they upgraded the LED backlight. I also notice the units run hotter, I know it cant be a defect because they both do it. I have to assume its the LEDs. Im thinking of adding a small fan to each unit, well at least to the unit thats working, I have to send the second screen back because of a dead pixel that is annoying me.
PLANNING [100%]
CAR PC ITEMS [100%]
INSTALL OF PC [50%]
BUG WORKOUT [90%]
INTERIOR MODS [75%]
BUDGET [380%]
HiJackZX1 Work Log
DodgeTalk
Old 02-24-2008, 11:12 PM   #12
greatwhite's Avatar
If it's running hotter, then it's not the led's.
Led's don't generate heat (not a significant amount anyways)................
Leonardo Da Vinci
Old 02-25-2008, 09:09 AM   #13
FusionFanatic's Avatar
the EBY701 uses a CCFL backlight... not LEDs
That depends on the LED... super-brights LEDs get too hot to touch... Luxeon LEDs get so hot they require heat sinks
FusionFanatic is offline   Reply With Quote
Old 02-25-2008, 11:32 AM   #14
Raw Wave
HiJackZX1's Avatar
thats true they dont, i forgot that....... wonder why they run hot!
PLANNING [100%]
CAR PC ITEMS [100%]
INSTALL OF PC [50%]
BUG WORKOUT [90%]
INTERIOR MODS [75%]
BUDGET [380%]
HiJackZX1 Work Log
DodgeTalk
Old 02-25-2008, 01:47 PM   #15
lor109's Avatar
Are We talking about the new 2008 EBY701? If it's not LED Backlit than what makes it brighter?
Troubleshoot Sync Mini Mac Lilliput screen Zedrush MacCar 2 03-27-2007 08:45 AM
Starting up lilliput screen without button PCB? Indust General Hardware Discussion 3 03-02-2006 10:10 PM
Lilliput screen wont turn on(buttons but no screen) how can i trouble shoot? MvF9884 LCD/Display 4 01-26-2006 03:35 AM
8" Lilliput question, extracting sound and screen rolls clean customs LCD/Display 5 06-30-2005 11:10 PM
FS - (New) Lilliput touch screen replacement calvincbr Classified Archive 1 01-27-2005 11:12 AM
