Need Help with cheesebox
I just purchased a cheesebox video converter from ebay and I am not sure if this is what I need. I want to hook up a backup camera and have it automatically switch the display to the camera when in reverse. I thought the cheesebox had a VGA input and switched to the composite input when it is turned on, however I dont see a VGA input on the unit. It has a VGA output, a power jack, a composite input, an s-video input, and a 9 pin D-sub connector. Is the 9 pin connector a VGA input to be used with an adapter cable and if so, can someone give me a pinout? If this doesn't have a VGA input, can someone recommend another unit that does? Thanks in advance!
