I got the LinITX TMR but its not fitting into the setup I have right now, the casing is about 7-8mm too tall, and i can't get it to sit flush. Plus, the LinITX casing is not wide enough to fill in the width of the car bezel's opening, I've got a few mm on each side empty. The Xenarc on the other hand fit perfectly both vertically and horizontally, and I got it to sit flush. So I opened up the LinITX case to see what I could move around or something, and it looks like the LCD sits on top of 3 separate boards which are screwed into the casing's back cover. What if I unscrewed them, drillied into a an empty xenarc casing, and remounted all of it? Do you think it would work out, or is this just a really stupid idea altogether? Getting the LinITX molded into my dash is going to be pretty difficult seeing as its too tall and not wide enough, so chances are the case would have to be redone somehow anyways, and then if I ever wanted to switch it out down the road it would be really hard with everything fiberglassed and bondoed together.
Here are some pics of how the Xenarc fits, maybe it will make more sense what I mean then.
