The MP3car.com Store
Thread Tools Display Modes
Old 03-01-2008, 07:01 PM   #1
My Photos: (0)
lilliput, how do I double the backlight?
Hi,
I have an extra lilliput laying around. I was thinking about gutting its backlight and adding it to the one in my car. IF I do this, how would I go about powering the extra bulb? Would I just solder/wire it to the same points on existing bulb, or controller?
any ideas? I have not a clue.
ironfinger is offline   Reply With Quote
Sponsored Links
Old 03-01-2008, 07:38 PM   #2
Confusion Master
Enforcer's CarPC Specs
Enforcer's Avatar
Vehicle: 1997 BMW E36 328I
My Photos: (1)
Quote: Originally Posted by ironfinger View Post
I have not a clue.
Then don't.
The voltage going into those backlites is very high and dangerous if you don't know what you are doing.
Search on the forum for backlite upgrades, there have been a few discussions and experiments but nothing really concrete.
Enforcer is offline   Reply With Quote
Old 03-01-2008, 07:43 PM   #3
greatwhite's CarPC Specs
greatwhite's Avatar
Vehicle: 2004 Chrysler 300M Special
My Photos: (1)
Also, double the tubes and light means double the heat. You're gonna have to find a way to deal with that too..........
Leonardo Da Vinci
greatwhite is offline   Reply With Quote
Old 03-01-2008, 07:50 PM   #4
My Photos: (0)
Question is Why? If you're interested in that, Google. I know some people have replaced the CCFL with high-intensity LEDs, which work out at less power for same or more light.
GutterClown is offline   Reply With Quote
Old 03-01-2008, 08:47 PM   #5
My Photos: (0)
"then don't?" eh? this is a DIY community yo. That does not compute.
Of course I aint gonna start randomly wiring stuff together. But if anyone could help that would be awesome!
Old 03-01-2008, 08:49 PM   #6
My Photos: (0)
why? for better sunlight readability. I alread have a transflective upgrade, but it still does not cut it. If they make brighter swap in backlights I would def go that route instead.
Old 03-01-2008, 08:59 PM   #7
Confusion Master
Enforcer's Avatar
My Photos: (1)
Yes this is a DIY forum, however when some asks how to do something and says they don't have a clue then they are generally looking at trouble. You should at least have some idea, before even thinking of doing what you are doing.
Basically the lilliputs are fickle enough as it is without trying to stick extra backlites in them.
And now you have declared you want to do this to a transflective, which has to be opened up in a sterile room to fit the special filters.
You either have too much money or not enough sense. (or both)
Old 03-01-2008, 09:09 PM   #8
My Photos: (0)
when someone asks how to do something and says that they have not a clue they are hinting that they are interested on some good howtos without coming out as being overly demanding for infomation. But you just read it like your typical know it all prick would.
Sterile room?
I doubt upgrading the backlight requires completely taking apart the layers, probably just the back. Plus many people here have done 3m upgrades without "sterile rooms" and have been more that happy.
Old 03-01-2008, 09:36 PM   #9
Confusion Master
Enforcer's Avatar
My Photos: (1)
Well when you have ****ed up your lovely working transreflective don't come running back here.
Old 03-02-2008, 06:53 AM   #10
My Photos: (0)
Ok, assuming you can pull it off.
Where are you going to mount said extra ccfl?
Sponsored Links
Old 03-02-2008, 09:03 AM   #11
CarFrontEnd Creator
iamgnat's CarPC Specs
iamgnat's Avatar
Vehicle: 04 Ford Escape
My Photos: (0)
I personally don't buy into the whole sterile room bit, but you have to be aware that any any dust or finger prints that get on the films will be magnified when you put it all back together again.
As far as this upgrade not having to mess with the films, you can't avoid it. You will have to pull out the existing backlight and modify it so that the light from the new one can pass through it. I assume that the 629 (the basis of the trans) is similar to the 619 (what I have) in how everything is sandwiched together.
As far as Enforcer's comments go, he is right. Yes this is a DIY forum, but when you are messing with the CCFLs you are messing with something that can kill you. We are more than will to help people out, but you can't expect people to jump right in and offer a howto to someone that says they don't know what they are doing when their life would potentially be at risk.
You are also far from the only one to want to make some kind of upgrade. A few searches in this forum would A) show you that there isn't a "bolt in" option available and B) what has been done (has anyone besides TC6 actually done it?) is not trivial.
I looked into doing it to mine, but never did because I found I didn't know enough to do it correctly or safely (looked into a second MFG option like you are, additional CCFLs, and LEDs). And even though it still works, my Lilli has never quite been the same since I disassembled it.
-dave
My pathetic worklog.
CarFrontEnd (now it's own sub-forum!!!!)
iamgnat is offline   Reply With Quote
Old 03-02-2008, 06:14 PM   #12
My Photos: (0)
yeah messing with an lcd can kill ya, so can installing a car amplifier. People aren't born with knowledge, everyone starts at zero and learns from there. The more one works on electrical DIY projects, such as car computers, car stereos, the more one gets better at dealing with new projects. It really is more a matter of knowing how to approach things safely, which in the DIY community involves recognizing one's current understanding then asking questions to fill gaps in that understanding.
Yeah I did a search and found people who successfully did it, but they didn't give any specific details about powering the extra backlight. That is what I was interested in. that was the gap that I had not a clue about, that was the dangerous part of the undertaking and that is why I specifically asked about it. But that's cool if that information won't be coming, I simply wont do such an upgrade.
Old 03-04-2008, 09:42 AM   #13
ThunderStick's CarPC Specs
ThunderStick's Avatar
Vehicle: 1986 Jaguar XJS
My Photos: (2)
WOW typical MP3CAR B.S.
Let's hate the person that asks the question first....
WOW... a whole new reason to have a forum....
86 Jaguar XJS - Completed
New Age - RR Skin
Blades Edge- RR SKIN
"Your two cents are worthless pennies if you consider the exchange rate for my 2 cents"
ThunderStick is offline   Reply With Quote
Old 03-04-2008, 10:30 AM   #14
john05srt4's Avatar
Vehicle: 2008 Scion xB
My Photos: (0)
+1
yea he asked is that a crime?
I hope you find out what your asking..then relay it to the rest of us..take care.
My Accord CarPC
john05srt4 is offline   Reply With Quote
Old 03-04-2008, 11:43 AM   #15
CarFrontEnd Creator
iamgnat's Avatar
My Photos: (0)
There is no hate, he got reasonable answers based on the criteria that he provided.
He says that he has no clue about what he is asking (and leaves it open if that is in regards to backlights specifically, working with high voltages/amps, or electronics DIY in general). He was told rather clearly by 3 different people that these back lights are not something to screw around with if you don't know what you are doing. Should we instead have given him the information that (without properly understanding it) could A) damage the screen, B) cause a fire, or C) killed or severely injured him? And in my experience, giving people information with the warning "may harm or kill" attached to it just doesn't sink in.
That should suggest that he (or anyone in a similar situation) does more research about the topic both in this forum and elsewhere, then come back and ask any questions for things he still doesn't understand.
I hope so too, but no one should be expecting to have something just handed to them. As I said in my previous post, I had similar ideas as the OP but I did the up front research and reading before I started asking questions. And like most other people came to the conclusion that it was not something I was comfortable tackling for a variety of reasons.
-dave
Sponsored Links
Trackbacks are Off
FAQ: Everything you need to know about your Lilliput hevnsnt LCD/Display 115 08-15-2008 03:38 PM
reversed polarity == Kentucky Fried Lilliput? hud LCD/Display 6 11-09-2005 07:39 AM
Lilliput backlight burnt out? [H]Bugster LCD/Display 8 12-29-2004 08:56 PM
FS: Parting out Lilliput 047025n Classified Archive 17 06-26-2004 07:52 PM
Lilliput Dimensions? I want to put one in my Acura Legend... Matt Whelan LCD/Display 2 06-19-2004 11:10 PM
Sponsored Links
Ad Management by RedTyger
