03-02-2008, 11:38 PM
#1
PanaVise Mount for LCD Touchscreen
Has anyone used one of the Panavise mounts for mounting a touchscreen like a Lilliput?
<www.panavise.com/f/comm/cell_slimline2000.html>
03-03-2008, 01:08 AM
#2
I originally mounted like that.
http://www.mp3car.com/vbulletin/717932-post8.html
I used it like that for two years, recently I started work on putting it in the dash.
2002 T-Bird, Via SP13000, Travla C158, M1-ATX, 1GB RAM, 120GB 2.5" drive, SlimSlot DVD-RW, XP, RR, Winamp, Xenarc 700TSV, HTC Touch PPC/Phone, BU-353 GPS/iG3, Elmscan OBDII, Griffin PowerMate, 2 Blaupunkt amps, Polk spkrs, 5 sec startup/S3 STR
~Jimmy
03-03-2008, 10:32 AM
#3
I made my mount using Panavise mounts. Don't know how well the pre-made mounts work, but I used two of their .815" ball and socket joints. My screen and aluminum enclosure weighs almost 5 lbs. and it does not move unless I move it.
I used this site for product. They were great to work with and sent out a few extra pieces at no charge when I had a problem.
www.panaviseonline.com
Getting quality goods and service is like buying oats. If you would like clean, fresh oats you must pay a fair price. If you would like oats that have already been through the horse, those are a little cheaper.
03-03-2008, 04:29 PM
#4
Thanks alot,
I'll have to look at the dash again. I like the Jlemieux method, but I really like what JimmyFitz said about using it on the mount for 2 years and then working on putting it in the dash.
The post method looks like it worked well for you.
I'm just starting, so I can work on getting everything else running and once I see how the location works, I can work on a better monitor install later.
03-03-2008, 06:43 PM
#5
Thanks alot,
The single post was good enough. It allowed it to swivel for the passenger to see it sometimes. I did remove one of the post segments to make it shorter, lower to the console.
~Jimmy
03-04-2008, 02:40 AM
#6
Ah, having good access for the passenger is a good idea.
Also, being able to move the monitor around a bit for glare, etc.
Thanks again,
| Thread Tools |
| Display Modes |
Linear Mode
