Well I did some more playing around and got the touch panel to work only when the outer plastic cover is off. It will still work if the front cover is on partially, but soon as put it completely back together with the screen all the way touching, it messes up. Almost like the screen needs to be spaced off. I tried foam to space it a little bit but no luck. I tried sanding the edge a little bit so there would be more room, but no luck.
Anyone have these symptoms?
