Old 04-12-2008, 08:01 PM   #46
FKA HiJackZX1
ZX1Cruizer's Avatar
ZX1Cruizer is just really niceZX1Cruizer is just really niceZX1Cruizer is just really niceZX1Cruizer is just really nice
Quote: Originally Posted by katit View Post
I already found schema with 2 relays and 1 capacitor which is very easy. It will do pulse on and pulse off which is good enough to "push" button.
It won't cover all scenarios, but will work for simple reverse gear application
How does it work? Post it.
ZX1 Cruizer
CAR PC ITEMS [35%]
INSTALL OF MULTI PC SYSTEM [35%]
BUG WORKOUT [0%]
INTERIOR MODS [45%]
ZX1 Cruizer Work Log
ZX1 Cruizer Website!
Please build up my REP.
ZX1Cruizer is offline   Reply With Quote
Old 04-12-2008, 09:10 PM   #47
katit is an unknown quantity at this point
Ok. Here is schema person on other forum designed (after 3 different ideas with microchips)..
Capacitor value will specify pulses duration C(in Farads) = T(time needed in seconds) / R(resistance of relay coil)
Two tiny 12V rated relays could be used
It works like that. When voltage supplied - capacitor will charge and second relay will be activated. As soon as capacitor charged - relay will deactivate. When voltage removed - capacitor will discharge and activate second relay.
katit is offline   Reply With Quote
Old 04-12-2008, 09:18 PM   #48
FKA HiJackZX1
ZX1Cruizer's Avatar
But the same thing can be accomplished with one relay, cant it, or is by using two it is avoiding the wierd issue were it turns all butons into PC/AV buttons?
ZX1 Cruizer
CAR PC ITEMS [35%]
BUG WORKOUT [0%]
INTERIOR MODS [45%]
Old 04-12-2008, 10:17 PM   #49
One relay will short those 2 wires on right permanently on +12 and then disconnect them when voltage removed. This will equal to you pressing "mode" button when going to reverse and holding it until you release button.
This schema will make 2 pulses. One when voltage applied (those 2 right wires will be shortef for specified period like you push and release button) and then when voltage goes out - it will do that "push" again.
Old 04-14-2008, 10:06 AM   #50
Robby BMW's Avatar
Robby BMW is on a distinguished road
Hi to all,
I've received an invitation to participate in this discussion by HiJack, and I've just finished to read all the posts.
Perhaps this could be helpful http://www.freewebs.com/billymcbunter/
_______________________________________
Car installation 95% [■■■■■■■■■■■■■■■■■■■]
Current project: Parking sensor USB interface
Robby BMW is offline   Reply With Quote
Old 04-14-2008, 11:24 AM   #51
FKA HiJackZX1
ZX1Cruizer's Avatar
Quote: Originally Posted by Robby BMW View Post
Hi to all,
I love you Robby..... When it comes to PIC and finding info on it, your the greatest. I knew you could help with this issue........
PS: um, can you translate this into newbie terms? Lol, I dont understand it at all.
ZX1 Cruizer
CAR PC ITEMS [35%]
BUG WORKOUT [0%]
INTERIOR MODS [45%]
Old 04-14-2008, 06:06 PM   #52
FKA HiJackZX1
ZX1Cruizer's Avatar
OK I downloaded everything and it looks like this requires AutoDesk DWG to open and read. Be ready this download is 193 MB, but from what I can read its free.
What is the EPC file Robby, what does it do, how do you open it?
ZX1 Cruizer
CAR PC ITEMS [35%]
BUG WORKOUT [0%]
INTERIOR MODS [45%]
Old 04-14-2008, 06:11 PM   #53
FKA HiJackZX1
ZX1Cruizer's Avatar
OK, I started looking and reading and trying to understand it better. It looks like its a circuit for controling 2 relays, its basically a complicated version of what you have proposed Katit.
ZX1 Cruizer
CAR PC ITEMS [35%]
BUG WORKOUT [0%]
INTERIOR MODS [45%]
Old 04-14-2008, 06:19 PM   #54
FKA HiJackZX1
ZX1Cruizer's Avatar
Is this something you have tried? What capacitors do you have to use?
ZX1 Cruizer
CAR PC ITEMS [35%]
BUG WORKOUT [0%]
INTERIOR MODS [45%]
Old 04-14-2008, 07:54 PM   #55
I didn't try it yet. Capacitor should be calculated depending what relay do you use (resistance of coil) and how long pulse have to be. You can build one quickly using 2 automotive relays and 1 500uf capacitor.
Old 04-15-2008, 02:21 AM   #56
FKA HiJackZX1
ZX1Cruizer's Avatar
Where is the capacitor on the drawing? I can only make out the 2 relays........ Tommorrow Im going to hop over to radioshack and get the capacitor, I already have the relays.....
ZX1 Cruizer
CAR PC ITEMS [35%]
BUG WORKOUT [0%]
INTERIOR MODS [45%]
Old 04-15-2008, 05:59 AM   #57
triath5147 is an unknown quantity at this point
The EPC file is a diagram of the PCB board. The usually green composite board that has the circuit imprinted on it. If you go to PCB123's web site, you can download their circuit design software, and open this file if you want to look at it. But it is mostly for submitting to PCB123, so their computer can make the circuit board for you. Than all you do is buy the componants and solder them to the premade board.
P.S. the capacitor in the drawing is ( +---||--- ) between the two relays at the top.
triath5147 is offline   Reply With Quote
Old 04-15-2008, 01:34 PM   #58
FKA HiJackZX1
ZX1Cruizer's Avatar
From your opinion... which set up is best? The PIC process seems to take time and cost more, and doesnt insure that the screen will flip correctly. The relay way has the same issue, but much easier to buy and cheaper.
ZX1 Cruizer
CAR PC ITEMS [35%]
BUG WORKOUT [0%]
INTERIOR MODS [45%]
Old 04-15-2008, 08:05 PM   #59
FKA HiJackZX1
ZX1Cruizer's Avatar
I bought the 2 relays..... they both have a coil resistence of 56 ohms +- 10 %, what capacitor do I need? I found a 220 UF one.
ZX1 Cruizer
CAR PC ITEMS [35%]
BUG WORKOUT [0%]
INTERIOR MODS [45%]
Old 04-15-2008, 08:46 PM   #60
I would try what you have and see how long is your pulses. You can use bulb on that circuit to test
Questions and Opinions on this CarPC setup for a 2005 BMW 325ci Shoey5 Newbie 6 12-01-2006 04:32 PM
My Planned System, Opinions Needed Wilsman00 Newbie 19 10-14-2006 04:30 AM
Lots of questions.. long post. rach Newbie 8 11-13-2004 10:53 PM
NewBie - Looking for opinions & A few questions.... DaveP General Hardware Discussion 10 07-11-2004 05:19 PM
Additional questions about LCDs: Is 400 nit too bright? khiser0001 LCD/Display 3 05-06-2003 07:13 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
