Old 03-10-2008, 06:21 AM   #1
sniiki is an unknown quantity at this point
Touchscreen pointer jumps to right edge
I recently purchased this 8" unnamed touchscreen. (EDIT. I think the lcd is NiceView or atleast it's sold with that name in some stores. brand of the touch panel remains unknown)
Note! This is not meant to blacken the shop at issue, I just dont know the brand of the panel so it's just for reference. Their service was really good and fast
It worked well several hours but now it's started to live a life of its own . The pointer constantly jumps to the right edge of the screen, always to the same place even if I don't touch the screen at all. I've tried to recalibrate it several times without any luck.
I can see that the touch element is bit off to the right so it might be that the right frame of the panel is pressing the touch element or something. Can't see any dirt under the frame or anything.
Recalibaring the screen helps for few a minutes but then the problem comes back.
I think I saw some distortion in the "calibration net" when I was clearing the 25 point calibration data from the driver software. I don't know if that means a contact problem or a constant contact in some place.
Panel uses Worcol Touch drivers.
Has anyone else had similar problems and is there a solution for it or should I try to return the panel? (which isn't that easy as I purchased it from Germany and I live in Finland)
I'd really want to open the panel and check if problem would go away when frames are removed but that would void the warranty as there's a sticker between the two halves of the cover.
sniiki is offline   Reply With Quote
Old 03-10-2008, 07:29 AM   #2
Neither darque nor pervert
DarquePervert's Avatar
DarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of light
Sounds like one side or corner of the touch element is being pinched, probably by the bezel.
LOOKING FOR THE FAQ? IT'S HERE.
You never found that link, did you? Why? It's hard to find in the NavBar across the top of the forums, amongst a lot of other crap.
TELL MP3CAR YOU WANT A LINK TO THE FAQ IN A MORE OBVIOUS, NOTICABLE LOCATION HERE.
Old 03-10-2008, 11:47 AM   #3
Yea I hoped it's that as I read several threads about similar problems and this was the usual presumed reason.
I however have loosened the screws on the problematic side and it doesn't seem to help. And when the problem isn't occuring and I try to press the right frame, I can't make the pointer to jump there like it does on its own. So I don't think it's becouse of tightness of the bezel.
Also, as there's that gasget between the element and bezel, I tried to push it deeper with a credit card. Seems to help a bit so I would guess it's either that or then just jammed area in the touch element and that area gets rubbed (which could help sometimes) while im stuffing the credit card over it.
Or in the worst case there's something wrong with the touch element controller
Old 03-10-2008, 01:23 PM   #4
Ok well.. no matter how much I loosen / crank the bezel it still jumps to the edge(check the image ).
Quite opposite it seems to help if I press the frame
Old 03-10-2008, 03:07 PM   #5
Hey, you're trying for the goal by going the other way around, you're crazzzyyyy!
HiJackZX1's Avatar
HiJackZX1 is just really niceHiJackZX1 is just really niceHiJackZX1 is just really niceHiJackZX1 is just really nice
If its not the bezel, then maybe it a software issue. Use the calibration tool that should have come with the packaging.... Hopefully that helps.
HiJack ZX1 CFSC
CAR PC ITEMS [35%]
INSTALL OF MULTI PC SYSTEM [35%]
BUG WORKOUT [0%]
INTERIOR MODS [45%]
HiJackZX1 Work Log
HiJackZX1 Website!
Please build up my REP.
HiJackZX1 is offline   Reply With Quote
Old 03-10-2008, 10:57 PM   #6
FusionFanatic's Avatar
FusionFanatic is an unknown quantity at this point
if the pointer is does not line up with where it is touched, then it is a software or calibration problem. but if it moves itself without you touching it then it's a hardware problem.
have you actually opened it up and adjusted the LCD panel mounting screws? or are you simply loosening the screws on the back of the plastic monitor housing?
loosening the screws on the plastic case/enclosure won't do any good. there are screws inside the enclosure that hold the LCD/touch panel in place (one of those screws may be too tight). if the panel is being forced against the bezel than you could try pressing on the side/corner that the pointer moves itself over to. this may push the panel far enough away from the bezel to sop the issue. if that doesn't fix it, then you'll have to open it up and adjust the panel retaining screws.
if you don't even know the brand name of the monitor, do you really need to worry about it's warranty? if you ever wanted to file a warranty claim on it, chances are you would have to pay to ship it overseas to Asia to have any work done on it (the shipping alone could cost more than the monitor itself ).
FusionFanatic is offline   Reply With Quote
Old 03-11-2008, 04:18 AM   #7
I've tried to recalibrate it several times but won't help. Only thing the software could be good for is if I could exclude the edge area from the area that's beeing scanned.
Yea you're absolutely right in that. **ck the warranty, just got new job anywayz
I'm not totally noob about these things and have opened LCDs before for DIY projector stuff but they where normal computer monitors so the structure is a bit different I think. In those the lcd element is just resting between front and back shell.
I'll try to pop the case open tonight. There's some clips holding it together which are always nice...
I'll post the results.
Thank you everyone for all the help so far
Old 03-11-2008, 07:40 AM   #8
What can I say? I like serial.
Curiosity's Avatar
Curiosity will become famous soon enough
Maybe it's the ribbon off the touch panel or something around there shorting. Maybe to the metal of the LCD housing. Resistive touch is like a variable resistor across the screen, so to the left would measure the least resistance. Or in other words, shorting would make it think it's all the way to the left.
Oh wait, right edge? If it's all the way right, then it should be a break in the ribbon or or bad connection.
XPort 1.41 -GPS port splitter, logger, and USB device resume fix
GPS DirectShow Filter / XOBD / MiniCam
Curiosity is offline   Reply With Quote
Old 03-11-2008, 08:17 AM   #9
Hard to say, could be so many things, but I really hope it's just too much pressure in some place *fingers crossed*.
But like said, I'll try to pop it open tonight so that should rule out few possibilities.
PS. If it's really the faulty touch element, there isn't much to do, right?
Old 03-11-2008, 01:33 PM   #10
Ok I performet autopsy for the poor bastard and unfortunately didn't find anything critical
I cleaned the edges of the lcd & touchpanel from top and under, centered the touch element as it was a bit off to the right, put it back together and tightened the panel holders just so that everything keeps in place.
Result? Same as before.
So I opened it again, checked, tested, opened again, checked... no luck.
It still can be the pressure somewhere as the this LCD unit really isn't made for touch function (there's parts of the plastic casing ripped of from here and there to get the touch element fitted). Also I didn't get the problem while testing the element while it was separated from the LCD, tho I did test it quite briefly only.
Anyhow well keep testing and reporting.
here's pictures to show position of the 4 clips (red arrows) so that if anyone would happen to open one of these.
Also added a cable tie (blue arrow) for the USB cable as it was on loose.
Old 03-11-2008, 01:52 PM   #11
Admin. Don't bug or I'll byte.
Bugbyte's Avatar
Bugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to behold
A wild shot in the dark, but is the ribbon cable from the touch panel to the touch controller plugged in upside down?
It wasn't clear in your post - you completely took the bezel off and tried it without anything touching the touch screen, right?
Seems a little fishy that it worked before you added it in and it doesn't now, but it isn't burned out or anything.
Want to:
-Find out about the iBug?
-Stop being a newbie? Take a look at the FAQ Emporium?
-Help me kill my car PC
-Watch live video streams from my mobile PC? Check it out here.
-Where is the iBug?
Bugbyte is offline   Reply With Quote
Old 03-11-2008, 02:19 PM   #12
Correction:
I didn't add the touch element, the panel was sold as a touchscreen. But you can clearly see that the touch element is added afterwards and not at the factory whoever made the screen itself.
And yes I've tried the touch screen sitting freely there. Don't think the cable is the problem and dont even know if it matters at all which way it's plugged as they're just resistors and before any calibration it acts all mixed up anyway.
And I found strange thing:
If I touch the screen VERY gently the pointer tries to jump to that place where it always stucks. Repeatedly touching the panel gently, the pointer will jump at the edge, always precisely at the same point.
Check the 5meg WMV video here:
http://users.evtek.fi/~anttimak/gara...ouchscreen.wmv
In the video the lcd is out of the casing and touch element sitting on it freely.
Old 03-11-2008, 03:03 PM   #13
Curiosity's Avatar
Looking at the video, I'd think it was another pointing device trying to take over. Got any other mice or touchpads hooked up?
Old 03-11-2008, 03:09 PM   #14
Yes mouse plugged in but I've ofcourse tested without it, it's not the cause either :|
EDIT. And I've also tested the touchpanel on another computer with same result.
Old 03-12-2008, 03:52 AM   #15
So following possibilities are ruled out:
-Pressure in wrong place (tested the touch element on its own)
-Computer specific reason (tested on a whole different setup)
-LCD panel's elektric interference (tested with the lcd power cable unplugged)
-Dirt (cleaned the element well)
That leaves me these?:
-intereference from outside source
-faulty touch element
-faulty touch element controller
This is again just a wild guess but are these things sensitive for outside interference? (dont think so). But last night when I moved the panel to other place and left it on running some visualization for hour or two, the problem didn't occur. (I know becouse the visualization is interrupted if mouse is clicked).
But the fact that the pointer jumps always to the excactly same position is referring to a faulty controller. This is just my opinion tho and maybe some else know better.
Hardware Review: Provision 8" 16:9 VGA Touchscreen lightman The Review Palace 19 06-15-2009 09:02 AM
Motherboard and Touchscreen don't love each other... kevpriest General MP3Car Discussion 2 07-27-2006 10:25 AM
touchscreen problem drives me nuts ! plz help diskey Input Devices 5 04-24-2006 10:15 AM
touchscreen edge not responsive workaround [H]Bugster LCD/Display 3 01-13-2004 02:33 AM
