Quote: Originally Posted by
pdiculous963
I bought it off ebay, i dont know the brand, my carputer is a laptop that will be powered by its auto cable, wired to a cigarrette outlet controled by a relay set on the acc line. I just want something separate from the connection of the laptop because they will be very far away. What can i use to keep the dc at 12 V and 1.5 A
you could just buy a dc-dc regulator. look in the mp3car store. your sure to find one. Of the two values you mentioned above, a few things you need to know. If something requires 12 Volts, you ensure the regulator is giving out 12 volts. If it requires 1.5 amps, you make sure the regulator you are using gives a minimum of 1.5 amps. anything more is fine.
