The MP3car.com Store
Thread Tools Display Modes
Old 03-23-2008, 05:40 AM   #1
My Photos: (0)
Best Motorized screen on the market?
i got an audi a3 and i'm looking for tha best motorized screen on the market for my mini carputer...????
mrzantos is offline   Reply With Quote
Sponsored Links
Old 03-23-2008, 05:44 AM   #2
Fusion Brain Creator
2k1Toaster's CarPC Specs
2k1Toaster's Avatar
Vehicle: 2001 Honda Civic EX Coupe
My Photos: (1)
there isnt. They all suck to be honest.
Also do you want 1-din or 2-din?
With 2-din you are limited to the DWW-650 (or equivalent branded models).
With 1-din you basically have lilliput and xenarc. Both are good. Xenarc has an auto-switch inputs for like a reverse cam from what I am told. The motor/worm gear in both of them will fail rather soon rendering your $400 to $800 screen useless or permanently ghettoed.
Old 03-23-2008, 12:45 PM   #3
My Photos: (0)
i was looking for 1 din... but if it sucks big time :-(
so if i'm going for anothere solution(i would really like a clean look).... what would you recomend?
Old 03-23-2008, 06:46 PM   #4
2k1Toaster's Avatar
My Photos: (1)
<personal taste>
The only way to get it to look clean is to make it look OEM which means a screen molded into your dash so it looks like the car came that way. I have never seen an OEM with a 1din flipout. It just looks cheap. Also when you press it, the screen will wobble or bounce back a bit which to me would be pretty annoying.
So time, a regular screen, some epoxy, bondo, primer, and paint and more time, you will have best results.
</personal taste>
Old 03-24-2008, 09:58 AM   #5
Nomader's CarPC Specs
Nomader's Avatar
Vehicle: Citroen Xsara 2002
My Photos: (0)
you might also want to check the k301 and the k90 (both chinese) my k301 still works fine after 2 years!..(metallic gears instead of plastic that liliputs used to have)
Nomader is offline   Reply With Quote
Old 03-24-2008, 10:47 AM   #6
nobb's CarPC Specs
My Photos: (14)
Motorized screens usually stick out a bit, so it definately does not look as neat and stock as a molded screen.
Ive taken apart my k301. Inside, it has metal gears and looks very solid and well built to me. But the opening/closing sequence does not feel as smooth as the new motorized xenarc, or the pioneer/alpines.
nobb is offline   Reply With Quote
Old 03-24-2008, 09:45 PM   #7
-zip-'s CarPC Specs
-zip-'s Avatar
Vehicle: 2000 Protege
My Photos: (1)
Been running an indash for a couple of years, If you want an OEM look forget about it. But sometimes there is little options. I only had a one din slot and did not have fab skills. The indash was a good option, but does not look like it is part of the car from factory.
Carputer
Installed Since April 2, 2005
Intel D201GLY|Fusion Brain|Audigy2 NX||ODBPros ODBII|Engenius362ext |Motorized lilli|GPS Rikaline 6010|Opus 150|Powermate|Ergonomic Touchpad|
Sound Stage
Eclipse CD8455|MTX TA3404+421D|Infinity Comps|ID 12" Sub
-zip- is offline   Reply With Quote
Old 04-01-2008, 02:37 PM   #8
imi
imi's Avatar
My Photos: (0)
I am in the same dilemna and completely agree with 2k1 here....its shocking that decent quality in-dash touchscreen done exist.
Can you guys post your in-dash installs please.
imi is offline   Reply With Quote
Old 04-01-2008, 05:00 PM   #9
Woofnstuff's CarPC Specs
Woofnstuff's Avatar
My Photos: (10)
I got one of these, they are cheapish hong kong screens, but are a manual eject.
one thing is they can swivel, like most screens they are average in high light.
but im pretty happy with mine, it has 1 VGA and 2 video inputs too for cameras as well.
http://item.b-billion.com/XDX/XDXP07...1D_billion.HTM
its about USD $233.00.
their automatic eject one can not swivel left/right, but has a tv turner as well..
Woofnstuff is offline   Reply With Quote
Old 04-01-2008, 05:38 PM   #10
imi
imi's Avatar
My Photos: (0)
thx, can i see more pics of the screen installed. want to see how much it sticks out of the din slot when closed if at all..
if i may say so, these do look better than the xenarc( that are twice the price) or am I missing something.
Sponsored Links
Old 04-01-2008, 06:05 PM   #11
Woofnstuff's Avatar
My Photos: (10)
check out my car pc profile
and when its closed it sticks out the same as a car stereo,
only issues i had with the install was you cant use long screws when you screw it in, or the screen gets locked in...about 3 washers fixed that.
the manual one is pretty robust, i havent broken mine yet.
the xenarc ones might be a better quality build or have a lower failure rate perhaps
umm.. its a 4wire touch screen, comes with drivers, mine setup real easy on win xp pro. right on the very edges (a few mm at most) and extreme corners are tricky to click sometimes, but once you skin it with a front end.. wont be a problem.
as i said its not a trans reflective screen, so can be hard to read in high light, esp if you wear polarized sunglasses. in general its viewable enough to drive and change music etc. with nav software most have voice guidance (and you shouldnt be reading a computer screen while driving)
thats my thoughts on them, and i was being pretty honest, im happy with mine.. if i had more money to spend i might look at these.. but at $750US, thats out of my current pricing
http://store.mp3car.com/New_7_Transf..._p/mon-052.htm
Old 04-01-2008, 06:26 PM   #12
imi
imi's Avatar
My Photos: (0)
Woof....buddy, thx for your opinion.
I came across a thread on this very helpful site where a company is working on a USB touchscreen adapter for alpine screens. Now that is something that would really suit my requirements perfectly. Not sure exactly what the timelines or price of that will be, perhaps for the interim period an cheap and cheerful solution like the screen you proposed is in order.
Can I ask you whether you can tilt your screen left and right....as my dash is angled towards the driver - i would like to tilt it left (UK) to point to the passenger.
Old 04-01-2008, 08:23 PM   #13
Vipsavior's CarPC Specs
Vipsavior's Avatar
Vehicle: 1993/Nissan/Gloria
My Photos: (0)
Thumbs up Heres one srcreen you might like
Well i was looking into the thermaltake monitor but i decided to go with a dash screen . If you are still looking around here is one http://www.techpowerup.com/reviews/T...ke/EmbeddedLCD
i never tried it so i dont know much about it . but this link explains more.
sorry for the typo I am retarded dee de dee
Planning 100%
Fabrication 100%
Components 100%
Computer 100%
Front End 80%
Live It Love It Slam It
Vipsavior is offline   Reply With Quote
Old 04-01-2008, 08:48 PM   #14
imi
imi's Avatar
My Photos: (0)
having researched this particular screen, i can see that you can tilt this from side to side which is great as my supra cockpit is tilted to the driver.
what i would ask you for is a side pic of the screen when it is out to get an idea as to how far is stretches out of its base unit.
here is my interior shot
Old 04-05-2008, 07:02 AM   #15
imi
imi's Avatar
My Photos: (0)
I ended up going for this, I reckon this screen would do me just fine until the Alpine Touchscreen adapter is available.
Sponsored Links
vB code is On
Trackbacks are Off
05 RX-8 custom fab install (motorized flip-up screen) zenfe Show off your project 20 05-15-2008 06:05 AM
Motorized drop screen AznRida LCD/Display 4 05-20-2007 03:49 PM
what I need is a motorized touch screen GPS wasss General Hardware Discussion 3 03-16-2007 09:41 AM
7" In-Dash MOTORIZED screen myfob General Hardware Discussion 3 01-25-2007 08:30 AM
WANTED, Mp3car MTSVO-SC Fully motorized VGA Touch Screen. cambo Classified Archive 9 09-06-2006 08:01 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
