Old 03-27-2008, 12:51 PM   #1
Lucky13ESP's Avatar
Lucky13ESP is on a distinguished road
Question TTL Help (was previously "LVDS cable help")
I've got a bare panel (Sharp LQ10PX22) and a board Advantech PCM-9577 that both support LVDS. The Sharp monitor specifies "18(6xRGB)x2 bit parrallel data signals, four kinds of timing signals, and +5V DC supply voltage for TFT-LCD panel driving." The Advantech board's data sheet states it "supports 2 Channel (2 x 18bit) LVDS interface."
LCD Pinout
Mobo Pinout
First question, are these compatible?
Second question, what sort of cable do I use to connect it?
The sharp monitor uses a Japan Aviation Electronics Industry Ltd KX14-80K2D receptacle and the Advantech board uses a Hirose DF13A-20DP-1.25V receptacle. I think I've done all I can do and now I'm in need of your expertise. Let me know if you need anything other specs (I found most of the data sheets). Thanks in advance.
Lucky13ESP is offline   Reply With Quote
Advertisement Sponsored links
Old 03-27-2008, 01:45 PM   #2
Raw Wave
Rob Withey's Avatar
Rob Withey is a splendid one to beholdRob Withey is a splendid one to beholdRob Withey is a splendid one to beholdRob Withey is a splendid one to beholdRob Withey is a splendid one to beholdRob Withey is a splendid one to beholdRob Withey is a splendid one to behold
That LCD pinout doesn't look like LVDS. Why do you think it is LVDS?
Systems retired due to new car
Rob Withey is offline   Reply With Quote
Old 03-27-2008, 02:07 PM   #3
Super Moderator. If my typing sucks it's probably because I'm driving....
turbocad6's Avatar
turbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to behold
yeah, that is not lvds display pinout, probably ttl I think...
turbocad6 is offline   Reply With Quote
Old 03-27-2008, 02:11 PM   #4
Lucky13ESP's Avatar
I guess I just kind of assumed it was since it matched the 2x18 of the LVDS of the mainboard. That is why I'm asking the community here which knows a lot more than me. Here is a link to the outputs available (i'm not including vga but it has a header too):
Available headers
Old 03-27-2008, 02:13 PM   #5
Raw Wave
Rob Withey's Avatar
It can be made to work. I'm running an 18 bit TTL panel from an LVDS output using a Advantech PCM3540 LVDS receiver to interface it.
Old 03-27-2008, 02:14 PM   #6
Lucky13ESP's Avatar
Ok, if you two agree it isn't LVDS then it must not be
I think that explains why I couldn't figure out the conversion between the two pinouts. I'll take a look and see what I can figure out now. I'm sure I'll have more questions for you including what is the max length of a TTL "cable bundle" Thanks so much for your quick responses.
Old 03-27-2008, 02:15 PM   #7
Lucky13ESP's Avatar
Would it be better to the route described above or straight TTL to TTL. I'm guessing the straight shot would be best but I'll wait for the gurus to weigh in.
Old 03-27-2008, 02:19 PM   #8
benedums's Avatar
benedums is an unknown quantity at this point
That LCD pin-out is most likely an 18bit TTL, at least that's what the signals would suggest.
If that's the case the the LCD and Controller would not be compatible.
The controller's pin-out is LVDS (Low Voltage Differential Signal).
You would need a controller that has an 18bit TTL output (to drive the LCD) and whatever input you are supplying from your PC (analog RGB (15-pin D-sub), DVI, or LVDS from your mother board).
The controller also has to support the native resolution of the LCD (the 18bit TTL output has to match the LCD resolution which is 1024x768 for the LQ10PX22).
There are two main types of display interfaces, LVDS and TTL. There are a few threads on here that describe the difference between the two if you're interested.
Sailin
________________________________________
CarPC Status:
Planning.......[--------x-] 90%
Parts..........[------x---] 70%
Fabrication....[----x-----] 50%
benedums is offline   Reply With Quote
Old 03-27-2008, 02:25 PM   #9
Lucky13ESP's Avatar
Thanks for the info benedums.
I'm almost positive my board supports TTL as it has a pinout table that includes diagrams for:
16-bit DSTN
24-bit DSTN
18-bit TFT
24-bit TFT
36-bit TFT
In this case I'm guessing the TFT is equivalent to TTL. Is this a mistake on my part?
I'll defer to you guys again but I do believe my display is 36-bit as it includes RA(0-5) and RB(0-5) as well as GA, GB, BA, and BB. I'm just guessing here but 6x6 = 36 bit? Thanks again for all the help.
Old 03-27-2008, 02:36 PM   #10
benedums's Avatar
16-bit DSTN
24-bit DSTN
18-bit TFT
24-bit TFT
36-bit TFT
TFT is the type of LCD (Thin Film Transistor) where TTL is the interface.
So TFT is not equal to TTL...
Most "new" motherboards that support LCD's (TFT, DSTN) do so with an LVDS interface, since that type of cable is less susceptible to EMI interference (TTL is more susceptible to interference).
There are several different formats of LVDS and TTL, each might include 16-bit thru 36-bit.
18-bit LVDS is not compatible with 18-bit TTL without a controller to convert it.
So it's likely that your MB only "directly" supports LVDS panels, unless you have a TTL connector on it, it probably only supports LVDS. Hence the need for a controller to convert the LVDS to TTL...
Sailin
CarPC Status:
Old 03-27-2008, 02:47 PM   #11
Lucky13ESP's Avatar
This page is from the user manual of the mobo. Available Headers
They appear to be different from the LVDS header.
Old 03-27-2008, 02:52 PM   #12
benedums's Avatar
what are the pin assignments of CN23 & CN18?
Sailin
CarPC Status:
Old 03-27-2008, 02:59 PM   #13
Lucky13ESP's Avatar
HeaderPin #Description
CN231VDDSAFE5 (+5v output)
CN232VDDSAFE5 (+5v output)
CN233GND
CN234GND
CN235VDDSAFE3 (+3.3v output)
CN236 VDDSAFE3 (+3.3v output)
CN237 NC
CN238 GND
CN239 R00
CN2310 R10
CN2311 R01
CN2312 R11
CN2313 R02
CN2314 R12
CN2315 R03
CN2316 R13
CN2317 R04
CN2318 R14
CN2319 R05
CN2320 R15
CN2321 G00
CN2322 G10
CN2323 G01
CN2324 G11
CN2325 G02
CN2326 G12
CN2327 G03
CN2328 G13
CN2329 G04
CN2330 G14
CN2331 G05
CN2332 G15
CN2333 GND
CN2334 GND
CN2335 SHFCLK
CN2336 FLM
CN2337 M/DE
CN2338 LP
CN2339 NC
CN2340 ENAVEE
CN181 GND
CN182 GND
CN183 B00
CN184 B10
CN185 B01
CN186 B11
CN187 B02
CN188 B12
CN189 B03
CN1810 B13
CN1811 B04
CN1812 B14
CN1813 B05
CN1814 B15
CN1815 GND
CN1816 GND
CN1817NC
CN1818NC
CN1819NC
CN1820NC
Last edited by Lucky13ESP; 03-28-2008 at 03:59 PM. Reason: I found the table command
Old 03-27-2008, 03:10 PM   #14
Lucky13ESP's Avatar
In the case that this is a 36 bit TTL output i've started matching up pinouts
I'm matching like so:
RA0 = R00
RA1 = R01
RB0 = R10
RB1 = R11
now for the trick part. I have these labels left over
On the LCD
CK (Dot Clock?)
Hsync (Latch Pulse?)
Vsync (First Line Marker?)
OHP-
ENAB
On the mobo
SHFCLK (Shift Clock?)
FLM (First Line Marker?)
M/DE (Display Enable?)
LP (Latch Pulse?)
ENAVEE
Let the matching game begin
Again, thanks for the help, I'm learning, albeit slowly
Old 03-27-2008, 03:56 PM   #15
benedums's Avatar
So is that from a motherboard or a controller board?
It looks like they split up the TTL interface between two connectors CN23 & CN18 which is a bit odd... none the less since the LCD is +5V you will not need to use the +3.3V... The ENAB on the LCD is probably the ENAVEE, CK could be SHFCLK, not sure where the Hsync and Vsync will mate to on the controller. and NC = No Connect...
I would be very surprised if this worked and didn't fry the controller or the LCD or both, so tread carefully.
It's best to find a controller that you know is compatible with the LCD...
Sailin
CarPC Status:
Building specific 40 pin TFT LVDS female cable to 20 pin JAE Female CON JacquesB General Hardware Discussion 6 09-22-2007 08:18 PM
Alpine IDA-X001 and High speed cable woes Lurkerlou Car Audio 1 08-13-2007 08:59 PM
Hardware Review: Custom LVDS LCD Cable by MotorCity Giuliano The Review Palace 3 04-27-2007 09:48 AM
Laptop TFT cable extension, strange problem predator1 LCD/Display 3 06-27-2006 05:08 AM
M10000 network card cable not detected warnockm General Hardware Discussion 7 01-04-2005 09:02 PM
