Sorry it took so long to reply, things have been really busy lately with finals and moving. Later this week I will post my build, pics, and review of that lm317 photoresistor setup. But since I have no display yet it will be a single led and if it 'works' at all for the intended purpose.
Quote:
Did you say it would be necessary to replace the existing backlight with these LED, or would the LEDs supplement the backlight already in?
That would probably be limited by space, if there was enough room to fit a row of leds on either side then I would guess that it would work well, my only concern is if the defuser will do a good job since (I'm guessing) it was not designed to have light from other places and give even light.
Quote:
Also, is it possible to control the brightness level like you do with a standard car's instrument panel? This is achieved using a variable resistor. If that is possible, would a variable resistor be used, or could PWM be used for more efficiency?
I'm sure it can be done, but it would end up being more complex.... probably. If 12v leds were used, or enough in series to take 12v then you could just hook the positive to the dimmer (assuming it is a standard car with ground as the frame/body and that the dimmer controls the positive). Since a car usually runs around 13-14v when on I would also use a 12v regulator to bring the max voltage down. If the dimmer is not attached to anything else you could also just use it for the pot in that variable regulator. The biggest problem I can see is during the day my dash lights are not on, yours might be, but unless the system is on it would not light up the display. I do like the idea that it could reduce the light output when on, but that would mean that 0v is full, 12v is just bellow full, and 10v is dimmed some... ect. So it would mean a rather complex circuit, but since you mentioned pwm I'm guessing that sounds as fun to you as it dose to me.
As far as pwm, leds can be controlled with pwm, but the pulse must be fast enough to make it seem as they are still on the whole time. I do not think it would be any more efficient, but it would... err should work just fine. The only problem I can think of is if you are drawing too much amperage for what ever you are using for pwm you would need some solid state relay or something, which probably will make it more expensive by a few bucks.
Quote:
Last but not least, if it is indeed necessary to replace the backlight that comes with the LCD, would it be necessary to leave the LEDs on at all times to be able to view the monitor, or could they be turned off when lighting conditions are favorable (like at night)? Road Runner has a feature that allows you to select a "day" and "night" skin, and I'm assuming brightness level has something to do with that.
Well without any form of backlight source, or transreflective display during the day, the only reason you can see the screen is the backlight. If you remove the ccfl tubes and turn off the leds then it would appear off unless you have some other light source.
