Notices
Old 04-12-2008, 11:50 PM   #16
Quote: Originally Posted by 2k1Toaster View Post
When you are on the PC is it always no signal, or does it show up for a bit, and then go away?
Can you use the touchscreen while the monitor is off and still get a response even though you cant see anything?
Have you hooked an external CRT monitor to your computer's output?
When im on PC , its always no signal input. no display at all...
can use the touch screen as i just formatted my pc, drivers not installed..
i hook a 15" lcd to my PC .. it works..
vaige is offline   Reply With Quote
Old 04-12-2008, 11:58 PM   #17
Quote: Originally Posted by bbalazs View Post
In that case there is no need to disassemble and reconnect every connector.
But vaige, please, just do not dip the information about your problem.
Did you check the functionality of the VGA cable? It was the same as you used on that 'your computer-foreign monitor' trial?
It is also possible that the converter chip went wrong.
sorry sir, what does "dip the information" means??
i have no way to check the VGA cable .. it seems the VGA cable that comes with the Lilliput screen is unique and has a different connector where the part clips to the LCD.
It works when i used a standard VGA cable when i was testing my computer..
Fyi, im using this cable to connect the lilliput lcd to my pc
then this
I have no idea how can i test the cable (VGA) whether its faulty or not...
Any advice? Thanks!!
Old 04-13-2008, 02:46 AM   #18
That means a missing letter, because the dying battery of my wireless KB.
DRIP the info. I meant, you give us the info in small droplets
Have you a multimeter? To check the VGA cable is on of the last and desperate thing to do.
Is the monitor still under warranty?
Alopecia perniciosa
bbalazs is offline   Reply With Quote
Old 04-13-2008, 11:37 AM   #19
oh lol, sir.. i have a multimeter, i have yet to test each contact point by point. i was intending to do so too and yea, im desperate already!
the monitor is still under warranty .. but im living in singapore and i ordered the lcd from the states.. shipping is gonna cost!
thanks alot!!
Old 04-15-2008, 11:05 PM   #20
I had this happen to me, but one of my connectors was just loose, the round one in this picture:
It took me a good 20 minutes to figure that it was loose
Also, this board is pretty informal and you don't need to call everyone sir
dyne is offline   Reply With Quote
Old 05-02-2008, 12:28 PM   #21
i tested the av cable with the multimeter, all sounds good. i have alsoed dismantle the casing and disconnect any reconnect back all connections..but still not signal. my usb touch screen is working now after i installed the software using a standard 15" monitor..
i suspect its the av cable thats causing the problem, the rubber protective for the wire seems to be kind of stiff. suspected the sun is causing it.
any gurus can advise where can i get a replacement for the av cable, im located in singapore.
Many thanks!
Hibernation / Resume issue with PhoCo zorro Centrafuse 15 10-09-2007 02:21 AM
I Need Help on some Pin-Outs r207 General Hardware Discussion 3 06-22-2007 01:02 PM
DWW-750FM No Input Signal drdream LCD/Display 0 05-30-2007 09:58 AM
HELP, Input Signal to AMP Power_nisse Car Audio 4 06-22-2005 12:35 PM
Need a lcd with s-video or rca video input!!! Need to send signal from my laptop!!! bankingdom LCD/Display 3 01-28-2005 04:32 PM
