The MP3car.com Store
Thread Tools Display Modes
Old 04-11-2008, 12:50 AM   #1
h3rk's CarPC Specs
Vehicle: 2006 Nissan Altima
My Photos: (0)
Lilliput FA841, 14 Pin Centronics pinout (verify plz) and several problems
It's killing me that I can't figure this out myself, but I've spent a little over a week on this one, this most recent time. I just don't know.
I have a Lilliput FA841-NP/C/T with a transflective upgrade, and an upgraded Fujitsu USB panel and controller (anti glare). I had sent the original back and appearantly the touch panel was bad. This was a Motor City Technologies job, and I'm excited to actually get to install it. But...
I've never been able to get the touch panel to make the computer do anything. And I would like some help.
I've seen several threads and posts on the subject, some of which include "unknown USB device" and other errors. I dont get any errors, but due to the lack of results I've spent some time digging in to things, I came up with this Pinout (14 pin Centronics cable):
It would be nice if someone could verify this for me.
I've verified all of the pins, most of the pins all of the way to components and their circuits on the PCB (scaler/USB/etc) so I'm fairly confident the pins are correct.
pins 6&14 seem to be USB data, ground was obvious, and it looks like the board makes it's own 5V for the touchscreen controller, and doesn't take it off of the USB Vcc bus.
I don't get any errors when I plug in, and all three versions of touchkit I've tried recognize the touchscreen controller in the software.
I've tried these Touchkits:
Win2000_XP_4.3.7.3321
All_In_One_2k_XP_Vista_5.0.0.5017
HIDUsbTouchDigitizer_2.0.0.0525
I did notice that the About page in All_In_One_2k_XP_Vista_5.0.0.5017, that it says it's for x64, but it installed fine and recognized the controller.
In hardware manager, I found:
I've read that in addition to the "Mice and pointing devices" device, there should also be a new device in "USB Controllers" is this true?
I've never found anything there, and I've looked every time.
I did try the tablet edition version as metioned above, and it seemed to install ok and recognize the controller:
and in the device manager it's a little different:
but I had no new results with touchscreen response.
I don't know what to do, I tried what one person has recently said about force feeding the driver after installing the touchkit, but that has not worked for me.
I've tried this on my car computer, a core-duo powered MSI Fuzzy 945GM1 (XP-Pro), and also on my HP, AMD Laptop (Pavillion dv6000)(Vista). And I've had same results with the touchscreen.
Any Ideas?
Also, on the Fuzzy945GM, the Lilliput wont display at 800x600, 1024x768 seems the only choice. 75 hz is problematic to make work (but it's needed for flicker).
On the laptop, 800x600 isn't accepted by the monitor, and anything above 1024x768 gives me a OVER-RANGE message on my monitor. (same I guess, but the results were more consistant on the laptop), 75hz is definately acheivable.
Well, this touchscreen was initially kind of expensive, and then when I sent back the display to MCT (after a long time having it sit and thus its more than fair that...) he had to charge me to fix it, so then I sprung for the upgrade. But now... I've sunk so much into it, I just can't stand that I can't figure out how to make it work.
MCT has been awesome, but I've had an email in to him for a few days now and I've had no response yet, must be busy. and I've been working on this for so long, I hope someone out there who has endured this long post, has some good advice for me.
I've also reseated and checked continuity across the FFC connector on a very small PCB (there's a very small pcb that takes a 4wire ribbon(FFC), where the four that plug into the onboard touchscreen controller are soldered on).
And Duayn, at MotorCityTech said he tested it before he shipped it off, so I have to be missing something...
Last edited by h3rk : 04-13-2008 at 12:55 PM. Reason: Various clarifications and typos
h3rk is offline   Reply With Quote
Sponsored Links
Old 04-13-2008, 04:05 PM   #2
h3rk's CarPC Specs
My Photos: (0)
Here's my troubleshooting progress so far.
I've checked continuity across that FFC connector, it's definately a problem, it needs pressure to keep reliable continuity across it but I don't think it's my only problem. (As of yet I don't exactly know what my problem is... maybe spending so much time fussing with this lilliput board.)
I've found the parts of the circuit that comprise touch controller: (the bit in the OP about having an 'upgraded controller' was a bit off, but that's what I understood from my correspondence with MCT. Monitors and LCD's have never been something I've spent much time digging into, so I'm learning much as I go).
This is a chip by Cypress, an enCoRe™ USB Combination Low-Speed USB and PS/2 Peripheral Controller. (datasheet)
I traced the centronics female connector pins 6 and 14 to this point before, looked up the chip, and didn't go any further it seemed right to me, but since I can't get things to work still, I go deeper. Again I've verified continuity from the centronics female connector pins 6 and 14 to pins 15 and 16 shown just above. Vcc is supplied onboard through the filtered regulated circuit which employs a LM7805.
At that circuit, I found 4.95Vdc, but closer to the USB circuit (pin 14) I'ts only 4.36Vdc, I was expecting less of a voltage drop. Both pins 9 and 10 are to ground as it says they should be in the data sheet. In fact if you look at this section of the board, and then look at TVI's USB 4-wire controller, they look very similar.
I am also figuring that the output of this circuit has to be functioning at least well enough to identify itself as a universal touchscreen controller in my device managers.
So now I move on to the rest of the circuit, now I haven't traced it all out yet, but it seems to me that the small chip nearest (lower corner) the CY7C63743 is part of an external clock circuit with the 6Mhz crystal oscillator. Please feel free to chime in and upgrade me though.
What's left is the input circuit: P0[7:0] and P1[7:0] and their connections.
On one side there are a few pins tied 3 202 smd resistors in parallel with eachother and seperated from gnd by that c104 cap to ground. I'm not sure if that's right (haven't probed too deep), I really have no idea how they coded the chip, and what they would use that for.
But on the other side of the chip there are several (4) more inputs from another chip whos markings I do not recognize, which I expect to be some A/D converting type of thing. It gets it's inputs from those items marked MC, I'm assuming some sort of transistor switches that fire when you touch the screen. ? (maybe memory cell? locking in the voltage from the last press until it can be looked at?)
When I take voltage readings on each of these pins, the top (in the picture above) is 4.36V, the bottom is 0V and the other 2 are... mostly they read around 0.020-0.050Vdc. I'm guessing they are the sensing pins. Which is like what little I know of how these 4wire sensors work.
No matter how well I seat and compress the flimsy little ffc connector, nothing responds. I did take continutity across it as previously stated, and I get 0 ohms *4. I did see a bit of voltage at one of the middle 2 pins once, but I can't really reproduce it.
What kind of voltage should I see?
As I understand it, the sensing wires pass along a voltage that drops fairly linearly across each dimension. I can't see that.
I secured the monitor and removed the touchscreen connector from the controller board. I checked continutity between all pins, and there was no continutity from the top pin or from the bottom pin to any of the other pins pressing the screen or not. But the two center pins had continuity to eachother when (only) I press the touchscreen. And this is through the FFC connector. lower left is like 250 ohms and upper right is 1200 ohms. Resistance varies directly with distance from the lower left.
I wasn't super sure what I expected to see, but I wasn't really expecting it to go like that.
Does that look right?
I also tested directly to the FFC ribbon traces, and got the same thing.
So there, I kind of quickly scanned through through the whole setup, and I'll have a picture up of the FFC connector and how it's connected soon, I forgot to take one of that. I'm also going to try to read up more on resistive 4 wire touchscreens and how the touchscreens 4 wires should be. What I saw really doesn't seem right to me. More on that later, I guess.
So...what should I do?
I'm thinking about just getting a whole different controller~$42, plug it into USB maybe get another FFC connector from digikey (hopefully one that's less flimsy and easily seperated) and a small PCB to solder to. if that doesn't work, maybe a new touchscreen (maybe one of the ones at TVI as well, I'm sure they work together) ~$56 for 8.4".
Then again, that NEC does look good (I just found the NEC 8.4 transflective thread today.
oh yeah I almost forgot....
Sponsored Links
vB code is On
Trackbacks are Off
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
