Old 04-11-2008, 02:34 PM   #1
hari-bhari can only hope to improve
Xenarc Ribbon Cable in a LinITX
I damaged my ribbon cable (I think) on my LinITX TMR and was hunting for a replacement, but could not find one. The mp3car store sells one for a Xenarc, though. I counted the number of pins, and both have 40. I also emailed them requesting the width, to see if it would fit my connector. If these match, is there anything else I should look into? I was thinking that maybe all 7" LCDs use identical ribbon cables, because the difference between a Xenarc and LinITX TMR is the reflective layers, not necessarily a difference in the VGA signal coming in. Any thoughts? Has this been done before (one brand cable into another screen)?
hari-bhari is offline   Reply With Quote
Old 04-11-2008, 05:47 PM   #2
zapro is on a distinguished road
The xenarc cable will fit. It's the same type of cable.
I have the cable from a Xenarc 700TSV in my TMR monitor. Just check that the wires is not crossed, and the cable is made that way, so one of the sides is stripped to the left, and the other to the right, then it's fine to use.
// Per.
zapro is offline   Reply With Quote
Old 04-11-2008, 06:32 PM   #3
thanks for the tips. Do you mean your linitx tmr? Also what do you mean by stripped on the left and right side?
Old 04-24-2008, 07:56 PM   #4
went ahead and ordered. confirmed as working. now i just need a replacement cable for the buttons, stupid thing got pinched and now does not work.
Anyone in Sacramento with Xenarc 700 series who will let me use their cable? Kelvrick LCD/Display 0 08-16-2007 05:13 PM
Where to buy Xenarc ribbon cable dmurray14 General Hardware Discussion 3 05-04-2006 10:06 PM
need replacement ribbon cable + connector keyvan LCD/Display 2 04-05-2006 02:22 AM
FS: Xenarc 700-IDT & 16-ft Cable - BRAND NEW! hd54321 Classified Archive 10 09-27-2005 05:02 PM
Need Xenarc internal cable help!! Tony S LCD/Display 4 11-16-2004 02:54 PM
