The MP3car.com Store
Thread Tools Display Modes
Old 04-17-2008, 04:03 PM   #1
My Photos: (0)
XGA upgrade to WXGA
Hi
i want to connect old laptop without screen with WXGA+ 1440x900 LCD
laptop is amilo 7830 , and factory it was equipmened with 15" 1024x768 XGA 30 pin LCD. New LCD also has 30 pin.
unfortunately motherboard plugs are dissimillar
WXGA+ LCD display cable plug (40 pin long)
and amilo motherboard has shorter 30 pin joint
did you hear about some converters or maybe displaycable with 30 pin motherboard joint designed for WXGA+
nyper is offline   Reply With Quote
Sponsored Links
Old 04-17-2008, 05:13 PM   #2
bbalazs's CarPC Specs
Vehicle: 2001 Renault LagunaII 2.0 IDE
My Photos: (15)
It depends on the type of the two LCD panels.
Seek the datasheet and match the appropriate pairs on each side. Just wiring. Be careful about the voltage (5V vs. 3.3V - I think both are 3.3).
The WXGA means longer CCFL also. It means slightly decreased backlight.
If even the driving methods (I think it must be lvds, but how many channels - usually three + clock) are equal, you have to face the problem of different resolution. You also have to modify the BIOS for this resolution and this is not easy at all.
If you are satisfied by a working windows, it is possible to set the resolution (if the driver of the video card supports) to the WXGA.
Alopecia perniciosa
bbalazs is offline   Reply With Quote
Old 04-17-2008, 05:20 PM   #3
My Photos: (0)
thanks,
Do you know website with those datasheets or any with database
Old 04-18-2008, 01:14 AM   #4
My Photos: (15)
Unfortunately not. Try Google 'LCD-type datasheet or pinout'
But you can also identify at least the number of LVDS pairs:
on the panel there are visible pairs, the resistance between them is about 100 Ohms.
There is another (additional) connector leading to the backlight panel? Or this is theonly one?
Alopecia perniciosa
Old 04-18-2008, 08:24 AM   #5
My Photos: (0)
answ
i don't know exactly what are Lvds pairs and what are they important to me.
ther is only one connector at LCD standard 30 pin as a whole new LCD
i have found datasheet for this lcd
here is link
http://www.pdfsea.com/en/down/down.php?downid=333&id=0
i need only datasheet for Motherboard 755II0 and it shlould works.
Old 04-19-2008, 04:01 AM   #6
My Photos: (15)
It is important to you, because it have to match. DDC pair is not TOO important. That pair provides info about the monitor.
I meant other connector as backlight panel connector. Of course, this LCD panel has only one bunch of cables.
Good luck for the conversion.
Alopecia perniciosa
Sponsored Links
vB code is On
Trackbacks are Off
Intel D201GLY2 low profile fan upgrade success! [pics] maniaxzero General Hardware Discussion 19 02-16-2008 09:12 AM
To upgrade or not to upgrade (PC) BRow86 Off Topic 13 08-16-2007 02:02 PM
Stereo upgrade, please advise htsource Car Audio 8 08-15-2007 10:11 AM
LCD Backlight Upgrade jcdillin LCD/Display 1221 10-09-2005 12:01 AM
Can I upgrade XP home to prefoessional? Skipjacks Software & Software Development 8 01-30-2005 08:06 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
