The MP3car.com Store
Thread Tools Display Modes
Old 04-20-2008, 08:21 PM   #1
Vehicle: 1999 BMW 323i Convertible
My Photos: (0)
Lilliput 629 Button board problems
Hello All,
a bit of issue I hope someone can help me with. I tried to add some wire to the infrared sensor and I think i fried it. All the buttons work, the infrared doesnt. Anyone know where i can get a replacement IR receiver for this board? or do i need to replace the entire board?
Alternativly, can i get a lengthened ribbon cable (the white flat thing that connects the button board to the main board). This would be probably be better so i can add the button board on the lower part of my dash. About 10 inches would be sufficient to relocate it to the spot i have in mind.
Any help and advise is most appreciated....
Thanks,
Amit
amk136 is offline   Reply With Quote
Sponsored Links
Old 04-27-2008, 12:47 AM   #2
My Photos: (0)
just put the ir sensor back on the board, i tried to lengthen mine to 12 inches and it would not respond.
i put it back and it works perfect. now i have tuo pull the dash to do any adjustments
drayday55 is offline   Reply With Quote
Old 04-27-2008, 01:36 AM   #3
numbers's Avatar
My Photos: (0)
I'd recommend using cat5 or similar cable for extending the button board. You could spend less time soldering all those wires on than you may spend looking for just the right ribbon cable.
As for the ir sensor, you can get a similar one at radio shack. Try putting it back first, though. As drayday said, it may not be bad. If it won't work when you extend it, it's either because of high frequency interference or voltage drop, and if it is voltage drop over just a few inches then you have a bad connection. I again recommend cat5 or any other twisted pair wire for this.
numbers is offline   Reply With Quote
Old 04-27-2008, 05:17 PM   #4
My Photos: (0)
i know it was over kill but i used 12 guage wire to extend mine and it did not work i checked for bad connections and all were ok. it should have worked but i just gave up on the deal. i dont have to do any adjustments anyways unless it goes outa sink
Old 04-28-2008, 09:58 AM   #5
My Photos: (0)
thanks for advice,
put the IR sensor back, didnt work, so have a ordered a few replacements. I have also ordered some 8" Ribbon cable from farnell.co.uk. I am going to try and relocate the button board with this lengethened ribbon cable and see if I can get it working. Its a 14-wire cable so will need a little bit of modifying, if it works, I shall let you know.....there is a thread somewhere on here with info about using this cable for this purpose.
amk136
Old 04-28-2008, 10:07 AM   #6
MySQL Error
Sonicxtacy02's CarPC Specs
Sonicxtacy02's Avatar
Vehicle: 2003/Acura/RSX
My Photos: (101)
i have a question pertaining to IR extension.. I Have a button board from an 8" lilli no longer in commission.. if i hack the IR off of that board and add it to the button board installed in my car without removing the current IR will i run into problems? I want to be able to basically add an ir point without permanently modifying the existing button board. Both IRs are the same.
03 Acura RSX Coupe
a K.I.S.S Flash, VB, and Autoit Programmer
HARDWARE PROGRESS: 90%[/////////-]
SKIN PROGRESS: 90%[/////////-]
Current Project: RRFusion, MovieTimes, RRMail and More!!! :)
Old 04-28-2008, 04:40 PM   #7
My Photos: (0)
Is the current IR in line of sight of the remote control? or is it hidden somewhere behind the dash? In theory I dont see it being a problem, but in practice, as a few of us on this thread have found out, adding even a few cm's of wire seems to cause a bit of a voltage drop and renders the IR useless. I personally think the best way to go is to move the whole button board to a location where it is more accessable. This is the route I'm going for and will let you know if the theory in my previous post works in practice.....
amk136
Old 04-28-2008, 05:07 PM   #8
MySQL Error
My Photos: (101)
the current board is definitely not line of site.. i need to add about 5 cms to extend it
03 Acura RSX Coupe
Old 04-30-2008, 07:47 AM   #9
My Photos: (0)
give it a go, let us know the results. I just received all the equipment from Farnell today, will give it a go in the evening and let you know if this lengthened flat cable does the trick.
amk136
Old 04-30-2008, 10:10 PM   #10
CLUCK's CarPC Specs
My Photos: (0)
I've move the IR sensor about 1metre (3feet) and it works 100%.
I did fry a capacitor in the process - too much solder heat, but I've replaced that.
CLUCK is offline   Reply With Quote
Sponsored Links
Old 05-02-2008, 04:29 AM   #11
My Photos: (0)
Does anyone know where I can get a replacement button board from?
Old 05-02-2008, 04:39 AM   #12
CLUCK's CarPC Specs
My Photos: (0)
Digital WW say thay have them but DO NOT order from that site, you will be charged but nothing will ship.
What exactly is wrong with your board ??
Old 05-02-2008, 09:35 AM   #13
My Photos: (0)
Nothing yet, just wanted to know that I can get a replacement should I destroy mine. I think I have fried the IR receiver. I resoldered it to the board, but it still does not work. Anybody know what frequency the IR receiver works at? The markings on it dont correspond to any "google" searches.
amk136
Sponsored Links
vB code is On
Trackbacks are Off
Problems with lilliput 8" dasaint80 LCD/Display 1 09-12-2006 08:04 AM
Lilliput button board (IR sensor extension)...did I fry it? Quack LCD/Display 7 03-11-2006 09:37 PM
WTB: Lilliput 629 IR Board gsj224 LCD/Display 2 02-27-2006 01:54 PM
WTB: Button circuit board for 8" Lilliput LCD. MustangCruiser Classified Archive 0 09-15-2005 11:02 PM
Lilliput 7" TS into TM-701L casing install problems :( NS98GSR LCD/Display 5 04-01-2004 04:37 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
