The MP3car.com Store
Thread Tools Display Modes
Old 04-27-2008, 06:58 AM   #1
My Photos: (0)
How to tell screen wire polarity?
Hi,
I bought a second hand screen off a memeber off this forum and he included the in car power wire with the "egg" chopped off, however i dont know which wire is positive and which is negative/ground?
I think the screen is a lilliput 619gl but there was no casign or box to confirm this.
One wire has a white stripe down it and the other is solid black.
I have checked on the controller board to see if it says if the pin or the outside is positive or negative but it does not say?
I have a multimeter and i can check which wire on the cable relates to the inside or outside of my barrel connector but how do i tell what the polarity is on the controller board?
grandimperial is offline   Reply With Quote
Sponsored Links
Old 04-27-2008, 07:07 AM   #2
Raw Wave
Rob Withey's CarPC Specs
Rob Withey's Avatar
Vehicle: '97 Vauxhall Corsa 1.5 TD
My Photos: (0)
The power ground is likely to be the same ground as the video ground on the VGA plug. A multimeter will tell you that.
6yr old first install died 20/8/2005 as result of bad bios flash.
New system : 6x5x2" contains 1GHz C3 PCM9373, ISR based PSU, 512Mb flash DOM, 8Gb CF HDD, 98Lite, DirectShow based frontend.
GPS : Rikaline 6010.
Display : LTM08C351 + LVDS receiver.
Rob Withey is offline   Reply With Quote
Old 04-27-2008, 07:10 AM   #3
hailrazer's CarPC Specs
hailrazer's Avatar
Vehicle: 2007 Gmc Yukon Xl
My Photos: (0)
Plug in the power adapter. Turn your multimeter to the Volts setting. Touch each wire with the mutimeter leads. If it says -12v the leads are reversed and change them . When it says +12v look at the leads. The black lead will be ground (negative) and the red lead will be positive.
Then look on the power adapter. It will say if it is a positive tip or negative tip power supply. Positive tip (-)------( O----(+) negative tip (+)-------(O------(-)
Then on the connector on the board hook it up the proper way negative or positive to the center of the adapter plugs center pin.
hailrazer is offline   Reply With Quote
Old 04-27-2008, 07:54 AM   #4
My Photos: (0)
Sorry im really confused by that,
What i have is basically two wires chopped off on one end and a barrel connector on the other.
So i cant plug my lead into a power supply.
One wire is a white stripe on it and th eother is solid black.
Would you mind explaining it agian to me,sorry and thanks?
Sponsored Links
vB code is On
Trackbacks are Off
How to: Build a heater strip to bend acrylic for 30 bucks or less! greatwhite Fabrication 9 06-08-2008 10:53 AM
LCD Screen: Does the Accessory wire have to be regulated too? nobb LCD/Display 6 09-29-2006 11:32 PM
Pseudo-FAQ: What Do I Need For A Carputer? Maheriano General MP3Car Discussion 18 07-03-2006 02:04 PM
FS: IBM Thinkpad 1400, National Display Systems Screen emailthis1 Classified Archive 8 10-02-2005 02:02 PM
Morex 60W car kit - 4 or 6 wire? MVShibui Power Supplies 0 05-09-2005 01:28 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
