The MP3car.com Store
Thread Tools Display Modes
Old 04-29-2008, 09:41 PM   #1
My Photos: (0)
Power Help / Suggestions
Hey Guys,
I will be powering a MacMini off of a Carnetix 1900 and will need to power three 7" LCD panels. One being a touchscreen and the other two will be headrest mounted monitors.
Any ideas of how I should power all three? Will I need to run another PSU like he 1900 down?
Clownzer
Clownzer is offline   Reply With Quote
Sponsored Links
Old 04-30-2008, 07:33 AM   #2
My Photos: (0)
Any Ideas on this one?
Old 04-30-2008, 09:57 AM   #3
golfguy's CarPC Specs
golfguy's Avatar
Vehicle: 2007 Mazdaspeed 6
My Photos: (0)
A Mac Mini specs out max continuous power at 110W from Apple's website. A Xenarc 700TSV is shown as <8W at Xenarc's website. A Lilliput is about 9W. A P1900 can put out 140W. So, assuming you have three screens and a Mini, you'll be almost to 140W. I would add one screen at a time and see what happens. You can always add another regulator if one of the screens pushes it too high.
Any day is a good day for golf.
Mazdaspeed6 Carputer Progress:
(Check Speedy's Worklog)
Purchase [*****] 100%
Design [*****] 100%
Install [****_] 90%
golfguy is offline   Reply With Quote
Old 04-30-2008, 10:03 AM   #4
Fusion Brain Creator
2k1Toaster's CarPC Specs
2k1Toaster's Avatar
Vehicle: 2001 Honda Civic EX Coupe
My Photos: (1)
Monitors come with regulators. Xenarcs are inside the monitor, and lilliput is on the wire in the "egg". No need to power them off your PSU at all.
Old 04-30-2008, 10:45 AM   #5
My Photos: (0)
Then how would you suggest powering them? I really don't want to use DC to AC converters and have a power strip running off of one.
Thanks!
Old 04-30-2008, 11:53 AM   #6
2k1Toaster's Avatar
My Photos: (1)
Just wire to the +12v from your car. That simple.
Old 04-30-2008, 12:09 PM   #7
My Photos: (0)
Duhh,
Awsome! Thanks again so like the computer I dont need to worry about the startup and shutdown "crank" issue. It wont blow all my LCDs out?
Old 04-30-2008, 01:13 PM   #8
h3rk's CarPC Specs
Vehicle: 2006 Nissan Altima
My Photos: (0)
The LCD's have power supplies either in them or as part of the DC power cable (for the lilliput). The LCD's power supplies turn your car's unregulated 12V DC into the regulated voltages it needs, regulated +12V.
Computers need power supplies too. But until a few years ago, your only choice was an AC in power supply that among other things provided regulated +12V and +5V DC output to the motherboard and all of the other components that plug in with those white 4 wire molex connectors. Since your computer's parts need regulated power, you can't just plug it into the car's 12Volt system, and besides, what about the 5 Volts?
In short: Yes, you do need either an inverter and AC power supply, or a DC-DC power supply. I'm sure this stuff is in the FAQ somewhere, but it's not like I'm killing trees, I guess.
h3rk is offline   Reply With Quote
Old 04-30-2008, 02:52 PM   #9
My Photos: (0)
Ok great write up! By this last part you meant... in short yes COMPUTERS need the inverter or the DC-DC power supply since LCDs do NOT need them because it is already built in.
Correct?
Thanks again
Old 04-30-2008, 02:57 PM   #10
h3rk's CarPC Specs
My Photos: (0)
Yes.
Now with Lilliputs, some people have had problem with the "egg" regulator, so people have used 12V 'point of load' regulators. If you want, look them up in the forum with the search feature, and then in the store if you want one.
Sponsored Links
vB code is On
Trackbacks are Off
FAQ: Power Supplies Explained (Part 1) Bugbyte The FAQ Emporium 14 06-10-2007 07:45 AM
FAQ: How to Wire an OPUS PSU Quattro The FAQ Emporium 74 08-26-2006 12:38 PM
suggestions on power supply scott_fx Power Supplies 43 01-21-2005 12:41 AM
FS For Sale 7" LCD VGA/USB, Opus 125w Power Supply, ATX P3-700 10GB 256r oudis Classified Archive 7 06-15-2004 09:29 PM
Install coming up... but Power questions technopsych Power Supplies 2 04-14-2004 07:16 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
