The MP3car.com Store
Thread Tools Display Modes
Old 05-04-2008, 09:43 AM   #1
My Photos: (4)
Lilliput 8" 889 - White Screen of Death?
Hi all, recently my screen started to go "no input signal".. so i tried with all i could.. this is the list of the things i did..
1) use multimeter to test connection on av cable. all works well.
2) used my laptop and applied extended desktop. touchscreen was working but same "no input signal".
3) i then dismantled the lcd , disconnect and reconnect every cable again.
4) Voila! i can see the windows bootup screen for 3 secs.. then gone.
5) i shutdown my pc, off my lcd.. restart pc and power up lcd..then i get the "white screen of death".
i have been doing quite alot of search. maybe due to lcd ribbon, bad fuse?
thing is im not sure which is the fuse that i should check on. tmr i'll use the multimeter on the ribbon to make sure there's no broken connection. im attaching the pics and hope any guru can give some advice.
ANY help would be appreciated.
Thanks in advance!
vaige is offline   Reply With Quote
Sponsored Links
Old 05-11-2008, 02:05 AM   #2
My Photos: (0)
Hello
Hey, I am having the same problem and its driving me crazy? Wondering if you found a Fix?
husein_100 is offline   Reply With Quote
Old 05-11-2008, 12:19 PM   #3
My Photos: (0)
I had a problem with this creen and the ribbon cable.
Then i also had a problem where it would get a light on the button board come on but nothing else would.
In the end i had to get a replacement controller board.
In your case i would definatley try a ribbon first. Its a horrible situation to be in and i hope you get it sorted
grandimperial is offline   Reply With Quote
Old 05-11-2008, 12:20 PM   #4
My Photos: (0)
Also make sure you do not power the screen when out of its case with controller board touching lcd......
I used a bit of card to slide between when testing it out of casing.
Sponsored Links
vB code is On
Trackbacks are Off
white screen of death, on a eby701. need help locating parts.... americasfuture2 LCD/Display 3 12-02-2007 11:15 PM
8" Lilliput screen hacking dupa2 LCD/Display 5 08-05-2007 08:22 PM
Lilliput died; white screen? bdqpdx2000 LCD/Display 16 05-09-2007 07:25 PM
Xenarc white screen of death? meddler LCD/Display 26 09-06-2006 12:21 AM
lilliput screen shutoff epdaniel LCD/Display 0 03-11-2006 11:17 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
