The MP3car.com Store
Thread Tools Display Modes
Old 05-05-2008, 09:49 AM   #1
My Photos: (0)
EBY701 USB modification
My touch screen layer broke (cracked) in my EBY701 (or equivalent ) Lilliput monitor. I just bought a new touch screen and touch screen USB controller for the repair. I felt better going with a new controller entirely because I think the onboard one has been defective and flaky ever since I first bought it two summers ago.
I was curious of WHICH wires inside the wiring harness are the 4 USB wires... 5v+ 5v- Data+ Data- so I don't have to run another USB cable under the carpet, just use the same USB cable thats already running through the VGA cable that came with my lilliput lcd.
If anyone has had any experience with that, any help is appreciated. Thank you
-steve
stevey500 is offline   Reply With Quote
Sponsored Links
Old 05-05-2008, 03:49 PM   #2
HiJackZX1's CarPC Specs
HiJackZX1's Avatar
Vehicle: 03 Dodge Durango SLT
My Photos: (231)
what color are the wires? i know on a typical USB set up its red, black, green and i cant recall the last color..... If you can get me the colors I can tell you what does what.
PLANNING [50%]
CAR PC ITEMS [75%]
INSTALL OF PC [80%]
INTERIOR MODS [35%]
BUDGET [380%]
HiJackZX1 Work Log
HiJackZX1 is offline   Reply With Quote
Old 05-05-2008, 11:43 PM   #3
FusionFanatic's CarPC Specs
FusionFanatic's Avatar
Vehicle: '07 Ford Fusion
My Photos: (56)
this is from an 8" Lilliput monitor; I'm not sure if it's the same connector and pinout as the EBY701, but it might help
even if you find an EBY701 specific pinout diagram I would still verify it with a multimeter before you solder anything. it's only 4 wires, so it should be fairly easy to find them.
FusionFanatic is offline   Reply With Quote
Old 05-14-2008, 07:35 PM   #4
My Photos: (0)
thanks!
Well. I ended up kinda screwing over my lilliput today. I bought a new replacement Digitizer from mp3car shop..
Got it, FITS great! Connector is in the wrong size of the screen, so i soldered some wires onto the connectors from the Touchscreen 4 pin connector on the board of the EBY701 and connected them into the touch screen plug of the digitizer panel.
didn't work, figured the EBY701 built in Touch screen controller wasn't compatible or something... I know for a fact I had a good connection, tried plugging in backwords also.
So... fidgeting around, I accidently ripped the video cable coming from the LCD panel to the main Lilliput board. Come to notice that the connector on the lcd might be damaged, unsure though, I don't have another cable to work with.
Heck.
So I bid on a new EBY701 that has a "turns on to just a blue screen, nothing further"
... so I'll just use my main board out of my eby701 in that eby701 I bid on.
Sponsored Links
vB code is On
Trackbacks are Off
Newbie build-up: Ampie CarPC EEEEeeee36 Newbie 56 03-28-2008 09:03 PM
Mini-ITX boards RedGTiVR6 General Hardware Discussion 88 01-10-2008 08:47 PM
USB self powered hub, which one htsource General Hardware Discussion 5 07-26-2007 03:31 PM
Via Epia Mii10000 USB buurin General Hardware Discussion 19 07-22-2006 02:52 PM
Problem with ITPS / hibernation and External USB HD veetid Power Supplies 5 01-02-2006 08:35 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
