Quote: Originally Posted by
galvitron
@RyanB95
Are those screws actually connected to the LCD from the board? Or are they acting as standoffs?
What I am getting at is: How exactly did you connect the LCD and board. Yours monitor is different than mine, I am just curious.
There are 3 tabs with screw holes in them and 3 silver screws in the baggy that came with the frame. My board lined up almost perfectly with the 3 holes in the tabs, and the board is screwed directly into the tabs.
The LCD is held on purely by the double-sided foam tape. There are tabs on the side with foam tape on them also. I bent those down over the LCD to give it extra support.
If I didn't answer your question enough then I'm not quite sure what you're asking. Perhaps more pictures would help?
Quote:
Quote: Originally Posted by RyanB95 View Post
I wonder if I'm going to need a double-din kit in my car to fill up any gap there might be between my bezel and the LCD frame?
Most likely yes.
Crap.
