LED's aren't brighter off the bat. It takes MANY LED to equal the power of one Fluorescent bulb.
We've already covered lower power and durability in previous posts. Modern laptops DEFINITELY do not count because of the size constraint we don't have in the car.
Again, this is DIY.
Tired of irrelevant conjecture, I decided to experiment myself to try to see why its not instantly obvious they are not used as stated in the post #1 brainstorm.
I agree heat is a problem. easy way around this:
Purchased solutions have their own hoods. this protects the top, bottom, sides, and read of the bulb. this just leaves the front of the bulb (LCD) that requires protection. This can be done via distance with some functional testing.
The bigger problem with the way I described the potential solution is that the LCD turns transparent when pixels are opened:
Bulbs are CLEARLY visible, and unless 100% coverage is achieved to exactitude, it is easy to see dark spots.
Furthermore, these are night shots. I don't have test data to suggest whether or not daylight readability is even possible via this method. will test tomorrow.
The solution is to modify the design slightly. Because the LCD has its own backlight, the diffusers are still there and can be added without using them all. This prevents bulb visibility without using ALL the diffusers which limit light emmitance.
But the practical solution must include cost, and there is no way around that. So I have to ask. What are people paying here to DIY their own LED backlights to achieve daylight readability?
I found a fluorescent desk lamp at Home Depot for $21 after tax. The hood is slightly over sized for a 7" screen, and the bulb slightly undersized. From an overall performance perspective, this is less than ideal because no matter what there will be a slightly dark spot to one side of the screen, left or right. Alternate bulbs exist, but would double the hardware cost.
The hood does not get hot at all but the bulb does, as stated before. The idea is by placing it one inch back dark spots will be eliminated while heat becomes a non-issue.
That is the theory, anyways.
