Notices
Old 06-11-2008, 06:52 PM   #1
RyanB95's Avatar
EBY-701 button board
Does anyone know where I may be able to get a replacement button board for the EBY-701? I checked digitalww and the mp3car store, neither has it.
Any chance a 619 or 629 board will work?
Thanks!
1995 AWD Tsi Talon
Carputer.
RyanB95 is offline   Reply With Quote
Old 06-15-2008, 01:31 PM   #2
RyanB95's Avatar
No one?
1995 AWD Tsi Talon
Carputer.
Old 06-30-2008, 10:04 PM   #3
RyanB95's Avatar
No one knows? I really need a new button board as I fried my IR sensor section of the board and need to have the IR sensor working. Thanks.
1995 AWD Tsi Talon
Carputer.
Old 06-30-2008, 10:15 PM   #4
Man, you don't need a new board if you just fried this sensor.
For the record, its next to impossible to fry an IR detector unless you've been modding it and ran it out of specs, but typically they shouldn't die.
What makes you think its the IR sensor?
colin is offline   Reply With Quote
Old 06-30-2008, 11:00 PM   #5
RyanB95's Avatar
No, I didn't fry the IR sensor itself... I destroyed the board using a soldering tip that was too big. I actually disconnected the leads in the board. Perhaps some pictures will help:
1995 AWD Tsi Talon
Carputer.
Old 07-01-2008, 01:17 AM   #6
Wow, that's dirty.
First off, I don't know where you can get one of these button boards.
With that said, I'd suggest that you hack it up a bit more, what do you have to lose? Buy a smaller tip ANYWHERE and it'll cost you less than the shipping cost of a new board. Then use a knife and cut the traces, etc etc etc. All IR sensors are the same, VCC IR GND (no particular order) so if you can find a vcc point you should be okay...
Why spend the money?
Old 07-01-2008, 04:19 AM   #7
Curiosity's Avatar
Yeah, just use a knife and scrape the green stuff off till you see a nice copper spot to solder to for each point. The ground plane above it, the trace on the side, and maybe the 3rd is on top? Just use some solid wire like a resistor lead or glue it down well because if it pulls it will rip the traces off the board.
XPort 1.26 -GPS port splitter, logger, and USB device resume fix
Curiosity is offline   Reply With Quote
Old 07-01-2008, 06:13 AM   #8
dLockers's Avatar
I threw my eby701 out the other day, otherwise you could of had it with the extended IR port already
dLockers is offline   Reply With Quote
Old 07-01-2008, 07:44 AM   #9
deeznudts's Avatar
I have one PM me and we'll work out the detials
My 2007 Scion Tc Install
deeznudts is offline   Reply With Quote
Old 07-01-2008, 05:45 PM   #10
RyanB95's Avatar
PM sent
1995 AWD Tsi Talon
Carputer.
Old 07-01-2008, 10:50 PM   #11
FusionFanatic's Avatar
why would you 'throw out' an EBY701 (or any monitor)??
it is worth money even if it doesn't work...
FusionFanatic is offline   Reply With Quote
Old 07-02-2008, 04:39 AM   #12
dLockers's Avatar
I posted it up for sale for $70 on here and no body wanted it
it was no good to me
so i threw it
Old 07-02-2008, 02:09 PM   #13
$5 > $0...
Super duper discount, I woulda sold it for 15 bucks before I just tossed it. Shame.
Old 07-12-2008, 01:38 AM   #14
did you find a button board? i have an extra 5$ plus shipping
zyrus1 is offline   Reply With Quote
Old 07-16-2008, 07:13 AM   #15
RyanB95's Avatar
PM sent.
1995 AWD Tsi Talon
Carputer.
Change Log iamgnat CarFrontEnd 12 03-19-2008 11:33 PM
iGuidance Hacks pbarrette GPS 47 12-28-2007 04:06 PM
Vista Ready board does not see XP only peripherals jdiazj1 General Hardware Discussion 15 06-05-2007 10:57 PM
LSX (VOID) released liquid_smoke RR Skins 1302 03-01-2007 11:43 PM
Determining button highlight order parksgm StreetDeck 2 12-19-2006 11:38 AM
