Old 06-25-2008, 08:59 AM   #1
Ricksastar's Avatar
What size screen can I fit? 7"? 8"?
I have a 2006 Ford Explorer and the opening where the stereo is 4.75H x 7.5W and 8.75 diagonal. The measurements on the screen that are listed are those with the bezel? I would like to fit an 8" if Possible..
Ricksastar is offline   Reply With Quote
Old 06-25-2008, 09:42 AM   #2
you can fit anything with enough modification. but your car has a standard double din opening and a 7 or 8 inch screen would fit the best.
jash7 is offline   Reply With Quote
Old 06-25-2008, 10:39 AM   #3
Ricksastar's Avatar
anyone have measurements for the 7 and 8" with bezel?
xenarc or lilliput doesnt matter
Old 06-25-2008, 09:51 PM   #4
FusionFanatic's Avatar
any store (including the MP3car store) that sells the monitors should list the outer dimensions [with bezel]... it's the LCD panel size itself that usually hard to find.
your stereo/dash opening measurements (4.75H x 7.5W); is that a factory radio bezel opening or is that the actual space available behind it?
FusionFanatic is offline   Reply With Quote
Old 06-26-2008, 02:40 PM   #5
it would be very rare to have a perfect fit, just find whichever is closest, and cut the bezel to fit. you will find that you could probably do either one.
trover4 is offline   Reply With Quote
2007 Mazda 3 Dash Screen looks OEM Splash-X Show off your project 52 07-07-2008 06:13 AM
Smallest screen size? navmaxlp Laptops, Tablets, UPMCs, etc. 10 02-28-2008 03:36 PM
Mercedes C280 8" Screen Installed tempgp Fabrication 2 02-27-2008 12:06 AM
touch screen size Bump LCD/Display 4 12-20-2004 10:08 AM
Lilliput VGA touch panel cracked. Would DigitalWW 7" touch panel fit ? shchua LCD/Display 2 12-11-2003 10:36 PM
