Old 06-25-2008, 01:08 PM   #1
Stealth915's Avatar
Help! Touchscreen not working
I'm having trouble getting the touchscreen on my 2008 model Lilliput 629. I purchased it from bybyte, prebuilt into a Mazda3 dash kit. The monitor works fine, and the touchkit software and drivers install perfectly. The only thing is when I touch the screen, nothing happens. I've tried running the calibration and the screen doesn't detect the stylus or my finger. Anybody have any idea as to what is the problem? I've tried uninstalling/reinstalling the drivers, and also have tried multiple USB ports. Still no luck. Please help!
I don't know anything about taking apart the touchscreen, but looking at the back of the unit, I noticed that the CN20 connector doesn't have anything plugged in to it. Could this be the reason my touchscreen isn't responding?
2004 Mazda3 Carputer Worklog - Update 9/12/08: INSTALLED!
Stealth915 is offline   Reply With Quote
Old 06-25-2008, 01:17 PM   #2
Fusion Brain Creator
2k1Toaster's Avatar
Check from the LCD to the controller board. There should be a clear 4 conductor ribbon from it to the board.
It could be backwards, loose, or missing. I would check that.
Old 06-26-2008, 05:45 AM   #3
GhostRiderDad's Avatar
I have a 889GL and the touch screen suddenly stopped working. It had only been in the car 3 days. It is possible that the connection for the USB stopped working because of a faulty or worked loose ribbon cable...and where do I look? Thanks
GhostRiderDad is offline   Reply With Quote
Old 06-26-2008, 06:57 AM   #4
Is the controller detected in Windows?
st1mpy is offline   Reply With Quote
Old 06-26-2008, 07:27 AM   #5
dLockers's Avatar
I have EXACTLY the same problem as you, same drivers, same firmware issue but using the innovatek 8inch TM868 iirc.
Detected in windows, no errors, installed via device manager then application/utility installed - still no go, tried it upside down & back to front to eliminate all possible angles and im still getting no feedback from the touchscreen.
PLEASE HELP!
dLockers is offline   Reply With Quote
Old 06-26-2008, 08:58 AM   #6
In my case, the USB is no longer being deteced. I've tried it in other USB ports and still nothing. did something fry on me?
Old 06-26-2008, 11:17 AM   #7
Machinehead's Avatar
Quote: Originally Posted by Stealth915 View Post
That connector is for the speaker, it doesn't have anything to do with the touch screen.
Machinehead is online now   Reply With Quote
Old 06-26-2008, 12:24 PM   #8
Stealth915's Avatar
Thanks for the info. I tried to find a ribbon cable on the unit, but I couldn't really see much without taking the unit apart. I decided to just send it back to ByByte to get it fixed.
Old 06-26-2008, 04:20 PM   #9
Does anyone kno why the USB would stop being recognized, and hence the touch screen not work? I had it in my car 3 days and it stopped cold. Thank goodness I have a mouse to use as a back up! HELP!!!!!
Old 07-07-2008, 11:58 AM   #10
angel120's Avatar
I'm having the same issue. My EBY701's touch isn't in Device Manager, but the video works perfectly fine. It used to work when I first got it, but no dice. I think the touch controller is screwed up.
2003 Mazda 6i Sedan - White
CarPC in the making!
angel120 is offline   Reply With Quote
Old 07-09-2008, 04:12 PM   #11
Snootch's Avatar
If the drivers installed fine, but you don't see anything when you open the touchkit program (no controllers detected), check the device manage in windows (right-click my computer, click on manage, then device manager on the left. On the list on the right you should see the touchscreen listed under "Universal Serial Bus Devices"
If not, then possibly tour USB controller board is non-functional. Send it back.
-Hope I could help
Look under USB
WORKLOG
VIA SN18000/1Gb GEIL PC3200/100Gb 2.5"HD/8" Phylon TS/BU-353 GPS/Powermate/M2-ATX PS
Webpage
Snootch is offline   Reply With Quote
Touchscreen install not working Skipjacks Input Devices 1 10-02-2007 07:43 AM
Touchscreen not working Ascension LCD/Display 5 06-01-2005 11:14 AM
Touchscreen problems with nlite and minlogon Ascension WinNT Based 1 06-01-2005 05:18 AM
Honda factory touchscreen to get DVD working? gadget Newbie 1 04-27-2005 03:53 AM
Lilliput touchscreen problem samc Input Devices 1 05-09-2004 11:12 AM
