Notices
Old 06-25-2008, 02:27 PM   #1
LED Backlighting (brightness control?)
in an effort to make our displays more readable, I will be experimenting with LED backlighting via some smt white leds placed around the plastic collector. is there any way to retain the brightness control on the lilliput controller board? is it operated by voltage adjustment before it sees the inverter, so that one could just cut out the inverter components?
my guess is no, since voltage adjustments before the transformer would mean big time changes after. im thinking the best way is to use a photosensor with a fusion brain to adaptively control it, based on the amount of light hitting the screen. any thoughts?
EDIT
going through some searching, answering my own questions.
tibby01 is offline   Reply With Quote
Old 06-26-2008, 03:13 PM   #2
visenri's Avatar
Screens that have a separate board for inverter (my xenarc 700idt does), have a control pin in the inverter connector used to control screen backlight.
Normally you get full brigh at 0V and minimum (off) at 3.3V.
Have a look at http://www.mp3car.com/vbulletin/lcd-...o-harness.html
If your lilliput has a separate board for the inverter it will be very easy to get this signal from the four pin connector.
Anyway, i think the photosensor is a very good option for auto backlight control.
WV GOLF V sportline with sempron 3100 under the seat.
My own software: http://www.solocarputer.com/phpbb2/viewtopic.php?t=7175
My carputer: http://www.solocarputer.com/phpbb2/viewtopic.php?t=6913
visenri is offline   Reply With Quote
Control devices via LPT and Bluetooth Towar Software & Software Development 10 08-25-2008 12:51 PM
Need wiring help for 2005 Grand Prix. derekmac Car Audio 33 09-21-2007 10:42 PM
LCD Backlight Upgrade jcdillin LCD/Display 1221 10-09-2005 01:01 AM
AIMEE Climate Control POLL Danceheaven Software & Software Development 19 08-21-2005 07:19 AM
