Laptop LCD b0rked!
Well after an 8-inch fall, while in the case, my 3 year old laptop display appeared not to work. This had happened before occaisionally, i would just open and close the lid a couple times and it would work. I discovered that the problem is not the image, but simply the backlight. I can see a faint image, and when i take it apart and shine a flashlight behind it you can see everything fine.
When i unplug the white and pink connector cables, the display has no change. I am going to grab a multimeter and measure the voltage between the white and pink cables. What should I expect? I am trying to find out if the screen itself is bad or if the inverter board is messed up (i am hoping this is the case cuz i can simply get a new one)
any thoughts?
Car: 1999 Dark Green Mustang GT Coupe
Audio: Alpine HU, JL 6ch Amp, JL Stealthbox and XR series components.
Player: Empeg for now; something custom later.
www.neotechpc.com - Custom built laptops!
