Old 07-05-2008, 03:39 PM   #1
Excellrec is an unknown quantity at this point
Just how much of a pain are the touchscreens?
I'm in the planning stages of my main project car right now and I'm just trying to figure out the general plan. What I'm wondering is how easy is it exactly to maneuver a touchscreen while you're driving in a car? I would guess it'd be damn near impossible. What I'm thinking is that I could just go with a trackball mouse and a keyboard for an easier to use interface. The keyboard obviously wouldn't really be for driving use unless by the passenger but the trackball would be my main point of interface.
So I'm just curious on what some of you have to say, obviously the other benefit is that non-touchscreens are going for pennies now that everyone is all about the touchscreens.
Excellrec is offline   Reply With Quote
Old 07-05-2008, 04:32 PM   #2
Maheriano will become famous soon enoughMaheriano will become famous soon enough
With a touchscreen the buttons are always in the same place. So if you want to change the track of volume, you know where to put your finger and only have to glance once to make sure you're hitting the right spot. With a mouse, you have to move it and then glance to see how close you are. Then move it again and keep doing that until you're on the button you want. Too much hassle for me.
Ampie Case
256 MB DDR2 PC5400
Xenarc 700TSV - VGA Monitor
Intel D945GCLF Motherboard
M2-ATX-HV
2005 Honda Civic
Maheriano is offline   Reply With Quote
Old 07-05-2008, 06:16 PM   #3
skuller is an unknown quantity at this point
both are too dangerous.
I never touch the touchscreen while driving.
skuller is offline   Reply With Quote
Old 07-05-2008, 06:27 PM   #4
Woofnstuff's Avatar
Woofnstuff is an unknown quantity at this point
i wouldnt try browsing windows folders etc while driving thats just asking for a darwin award.
my audio player skin has big buttons and limited functions...
anything more than next track or pause, its too much while driving.
the touch screen is great if used with common sense
Woofnstuff is offline   Reply With Quote
Old 07-05-2008, 06:52 PM   #5
Fusion Brain Creator
2k1Toaster's Avatar
2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future
I have no problem navigating my touchscreen and I can do it without staring at it. The same amount of concentration used to glance at a normal HU really. Mouse/Trackball is waaaaaaay more dangerous.
Old 07-05-2008, 07:07 PM   #6
i should add that I plan to have a transport button pad molded into the center console as well so simple functions such as starting and stopping and changing tracks will be handled by that. So basically the exact same as I do with my remote for my headunit now.
Old 07-05-2008, 09:25 PM   #7
pancit175 is on a distinguished road
If you are using a front end, which you should already be considering doing so, navigating through the menu screens is easy while driving because they have large buttons and in some cases gestures. And the front end useally has only the functions you should be needing while driving, ie media nav etc. Navigating through your operating system is simpley reckless while driving.
PROGRESS:
pancit175 is offline   Reply With Quote
Old 07-06-2008, 07:13 AM   #8
Snootch's Avatar
Snootch is on a distinguished road
I would plan on using multiple input functions. For instance, I use Streetdeck which uses gesture inputs (so does Centrafuse), so all I have to do to go to the next song, is swipe my finger from left to right across the screen, OR I can push and rotate clockwise on my Powermate, OR I can push the track + button on my steering wheel controls.
Which input I use really depends on how much attention driving requires at the time. If i'm doing 70 down a road with a bunch of twisties in it, I'll feel and use the steering wheel control. If i'm using cruise control on a deserted interstate, I'll take my eyes off the road for a second or two and use the touchscreen.
WORKLOG
Asus P5N73-AN Mobo/Celeron E1400 2Ghz Dual Core CPU/2Gb GEIL PC3200/120GB HDD/DSATX PS/8" Phylon TS
Webpage
Snootch is offline   Reply With Quote
Old 07-06-2008, 08:08 AM   #9
sxott is on a distinguished road
True. Touchscreen I can do w/o looking it is easier than my HU.
My Install
sxott is offline   Reply With Quote
Old 07-06-2008, 10:23 AM   #10
greatwhite's Avatar
greatwhite is an unknown quantity at this point
I've incorporate my vehicles stock steering wheel controls........best input method!
Other than that (hard buttons somewhere), touchscreen is the only thing you should attempt to use when driving. Even then, only for pause, play, ff, rwd, vol etc. Anything requiring you to look should be done when stopped..........
Leonardo Da Vinci
greatwhite is offline   Reply With Quote
Old 07-06-2008, 10:25 AM   #11
AltimateX's Avatar
AltimateX is an unknown quantity at this point
Simply put, a touchscreen is invaluable compared to a mouse. You think its hard trying to use a touchscreen while driving? Try using a mouse
The best option would be voice control
AltimateX is offline   Reply With Quote
Old 07-06-2008, 05:09 PM   #12
2k1Toaster's Avatar
Quote: Originally Posted by Snootch View Post
I would plan on using multiple input functions. For instance, I use Streetdeck which uses gesture inputs (so does Centrafuse)...</snip>
So does RoadRunner and it is free
Old 07-07-2008, 11:09 AM   #13
Machinehead's Avatar
Machinehead will become famous soon enoughMachinehead will become famous soon enough
Exactly, I use a ripped apart nulooq navigator with RR.
Machinehead is offline   Reply With Quote
FAQ: Touchscreens explained RedGTiVR6 The FAQ Emporium 1 07-21-2008 11:10 AM
Multiple touchscreens on one PC? jm1133 General Hardware Discussion 27 07-02-2008 03:45 PM
Running Multiple Touchscreens tschallb LCD/Display 3 03-03-2008 08:27 PM
Theory on why Lilliput touchscreens die archimense LCD/Display 3 08-27-2004 02:12 AM
Just a heads up for those looking for touchscreens Odie LCD/Display 1 02-27-2003 08:29 AM
