Old 07-05-2008, 03:48 PM   #1
l33der is an unknown quantity at this point
Can I cut the extra cables off my EBY701?
I have nearly finished my little project to install my Lilliput EBY701 screen on a rail and hinge in my dash, the only problem left is cable management. The way I'm doing things, the RCA/power(? I'm not sure what this is, it fits the power plug, so I assume it's a power extension?) cables constantly get in my way. I have no need for them, I'm just using the VGA and USB - so can I cut these off, without creating problems for normal operation? I can't see anywhere to order a replacement cable for this thing if I mess it up, so I'm being extra cautious.
edit: I went and did it anyway, because I found an eBay seller with the cable. It worked out great, I'm all set now!
l33der is offline   Reply With Quote
Old 07-07-2008, 12:25 PM   #2
ZanGManN
I dont really know what wires you're referring to, but can you just detach them from whatever board? Do you have pictures?
ZanGManN is offline   Reply With Quote
Old 07-08-2008, 10:57 PM   #3
NiSlo's Avatar
NiSlo is an unknown quantity at this point
Yes you can cut them off. I cut mine off with no issues. Just make sure when you do cut them, you isolate the wires (the inner wire and the outer sheath) so that noting touches...
I installed my carpc into my pet Kangaroo, mate.
NiSlo is offline   Reply With Quote
Old 07-08-2008, 11:39 PM   #4
I ended up pulling them out entirely (removing the pins from the head) because I had already removed the plastic cover for it, so it was simple that way. I still need to figure out a better way to manage the rest of the wire though, it keeps getting snagged when it slides. Other than that it's all gravy now.
what to cut with and how to do it right? TheFaze Fabrication 5 04-21-2006 02:42 PM
25 wire data cables peecee General MP3Car Discussion 0 04-03-2006 09:59 AM
False floor i3igmind Fabrication 29 02-04-2006 11:28 PM
Anyone have pin/wiring info for 629 Cables? lax4321 LCD/Display 0 08-10-2005 10:46 AM
din cables jasmar Classified Archive 0 02-27-2001 10:21 PM
