Old 07-06-2008, 10:54 AM   #1
Brib3 is on a distinguished road
Lilli EBY701 flickering/lines problem
Hi. I have some problems with this 701EBY screen... I get intermittend horizontal lines on parts of the screen from time to time. I cannot recreate it, but it seems to be more constant when I use the mouse/touchscreen.
This is all powered AC, since I am just bench testing it right now.
Any ideas what the problem could be?
Thank you.
Brib3 is offline   Reply With Quote
Old 07-06-2008, 11:28 AM   #2
greatwhite's Avatar
greatwhite is an unknown quantity at this point
Check to make sure the round plug in the signal wire is tight. the vga/usb cable that is.....
Leonardo Da Vinci
greatwhite is offline   Reply With Quote
Old 07-08-2008, 10:10 AM   #3
nst6563 is an unknown quantity at this point
and if it's really tight, try loosening it just a tad. I've had the same issue when that round plug is both too loose and too tight. the connection just plain sucks, they need to come up with something better.
nst6563 is offline   Reply With Quote
Old 07-08-2008, 10:28 PM   #4
Kosti is on a distinguished road
I have a similar problems where I think mine is similar to white noise or electromagnetic radiation / interference?
The HDD is very close to the screen and so is the ATX PSU cable, would these affect the LCD screen and how would I go about sheilding it?
don;t mean to hijack your thread mate!
Below is a snap shot of how it's housed
Parts list - in AUD$
Lilliput 629 $270 | Hitachi 5400RPM 80G $92 | PIO DVR-K05 slot $95 | AYAY SIR Quad port GPS $160 | DSATX 220W PSU $205 | Mechatroniks Bezel $186 | Kino-9453 MB $380 | A-Data DDR2 667 2Gig $140 | 2 X CCD Cameras $180 | HQCT -e $140 |
Kosti is offline   Reply With Quote
Old 07-08-2008, 10:48 PM   #5
NiSlo's Avatar
NiSlo is an unknown quantity at this point
Oh man, I'm gonna need to look into doing the same as you Kosti in my Impreza. At the moment the computer is in the boot as I couldn't fit everything in the standard Mechatroniks chassis, but that looks sweet! Heaps of room for air to move around too.
B.O.T. - I had wavey lines all over my screen when I was putting it together and thought it was the long (5M) VGA cable I was using. After exchanging the VGA cable with no difference, I ended up changing the video settings in the BIOS to a lower resolution and the lines dissapeared!
I installed my carpc into my pet Kangaroo, mate.
NiSlo is offline   Reply With Quote
Old 07-09-2008, 03:28 AM   #6
thank NiSlo, its an old pix, but it's much the same, I'm still working on the resolution so I guess this is part of the problem, just curious is shielding is required
DSATX problem, not power switch problem! VThokieME Power Supplies 4 05-04-2008 01:22 AM
Problem With Liliput EBY701 angel120 LCD/Display 19 04-15-2008 09:21 PM
Not your typical flicker problem JPuma LCD/Display 17 05-30-2007 10:28 AM
had an all day (9 hr) problem at work.... wizardPC Off Topic 13 10-20-2005 12:50 PM
What could be the problem with my Lilli? BoyNextDoor LCD/Display 18 08-21-2004 04:32 AM
