Old 07-09-2008, 02:07 PM   #1
tazyman is an unknown quantity at this point
Portable DVD player as a cheap screen?
Yes, the title says it all... I am cheap!
I would like to start off with a carcomputer project and try to minimize my initial outlay of cash.
So I would like to consider the possibility of using my old Toshiba laptop (which has a composite video output) and a portable DVD player (say, 8" screen) as the screen. I noticed that some of these portable players support A/V input (possibly for use as screens for game consoles).
Is this a viable option if my intended use of the car computer would be:
- GPS
- Music album navigation
- Limited browsing (where WIFI is available)
Thanks in advance.
tazyman is offline   Reply With Quote
Old 07-09-2008, 04:58 PM   #2
Punky is on a distinguished road
if the long run you're going to hate having a screen thats not vga:
1) it's not that much cheaper, since they run around 100 new, which you could buy a used lilliuput for.
2) It's got no touchscreen, which some people could live without.
3) it looks like *** compared to a vga screen.
So my advice, wait and save up to buy a real vga screen, its definitely worth the wait.
Punky is offline   Reply With Quote
Old 07-09-2008, 11:54 PM   #3
FusionFanatic's Avatar
FusionFanatic is an unknown quantity at this point
'less-than-VGA' monitors look like crap when hooked up to a composite monitor. hook your laptop up to a regular TV and you'll see how bad it looks; then picture in your mind how hard it would be to use a screen like that while driving
- GPS
it depends on the GPS software you're using, but in general the answer is: yes. GPS software made for carPCs (like iGuidance) will look ok on a composite monitor, but you can forget about using anything with small text.
that depends on the front end you use, but in general the test on most front ends is large enough that you could probably see it without an issue (but it won't be pretty )
with a composite monitor, web browsing will be almost impossible. I suppose you could increase the font size to make text readable, but then you could only see a small piece of the web page at a time (which IMO makes it completely impractical to use).
the bottom line is; just but a VGA screen. you'll be much happier with your setup if you do. you can get VGA monitors on eBay for around ~$150 (sometimes even less).
good luck
FusionFanatic is offline   Reply With Quote
Old 07-10-2008, 12:00 AM   #4
SD beats everything. So there.
danielkh's Avatar
danielkh is an unknown quantity at this point
Ok, here is my take on this. If you are going to be cheap, find somewhere else to do it. The monitor is the only part visible and is pretty much the center of your entire system. It is the ONLY place you shouldn't even consider skimping on. Heck, buy and old 386 laptop running windows 95 if you really want to save money. The touchscreen isn't the place.....never.......ever.
Of course, try to get the best deal, but dont try to cut corners. You'll hate yourself if you do. And in the long run, it's going to cost you a good touchscreen AND the cost of the craptastic one.
My opinion is my own.
danielkh is offline   Reply With Quote
Old 07-10-2008, 12:15 AM   #5
Super Moderator & Wal-Mart Greeter
Tidder's Avatar
Tidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant future
- GPS
Thanks in advance.
Here's my take on it. I used a psOne 5" screen for almost 3 years in my 2nd CarPC build (first one was a 4x20 character LCD!) with a 5.6" touchscreen overlay from digitalww. It was awesome for just about everything EXCEPT browsing/text. Don't expect web pages to be readable, but could possibly kick up the txt size and have a bit of usability. But GPS/Nav, music, and video would be awesome with it, given you use a good frontend and nav software with big text. Also another problem you may run into is some composite vid out have a limit of 640x480 or 800x600. My 5" psOne screen had 640x480 limit (hacked it for VGA anyway). Was good enough for me at the time, but doing Nav on a 640x480 would bite the big one. And it did which is why now I'm using a lilliput.
Tidder
Try RevFE
The best frontend I've ever used, period.
Best Quote EVER!!
Quote: Originally Posted by bramlet View Post
I try to search but I usually only find posts where people ask questions and darquepervert tells them to search.
Tidder is offline   Reply With Quote
House dvd player in the car & Innotek ebay screen? hmm thesupe87 General MP3Car Discussion 8 09-07-2005 12:30 PM
