Notices
Old 07-14-2008, 04:17 PM   #1
Snootch's Avatar
Using unregulated 12v okay on LED backlight screens?
Just as the title says... Is it okay to tap into the car's unregulated 12v (cigarette lighter) to power the screen if the screen is using a LED backlight? All the threads i've read regarding powering the screen say use regulated 12v from a power supply to prevent blowing up the CCFL inverter. So is a LED backlight okay?
WORKLOG
VIA SN18000/1Gb GEIL PC3200/100Gb 2.5"HD/8" Phylon TS/BU-353 GPS/Powermate/M2-ATX PS
Webpage
Snootch is offline   Reply With Quote
Old 07-14-2008, 04:19 PM   #2
Self proclaimed spoon feeder
TruckinMP3's Avatar
depends on the internal regulation and if the documents say it is OK.....
What does the doc say?
TruckinMP3
Read the FAQ!
TruckinMP3 is offline   Reply With Quote
Old 07-14-2008, 04:58 PM   #3
Snootch's Avatar
The only thing regarding power that the manual covers is this: "Power Source: DC12-24V", and "Power Consumption: 600mA(max)"
The screen in question is the Phylon 8" open frame from Logic Supply.
WORKLOG
Webpage
Old 07-14-2008, 05:55 PM   #4
TruckinMP3's Avatar
That is your answer then 12 - 24 is a large range.
TruckinMP3
Read the FAQ!
Old 07-15-2008, 02:28 PM   #5
Some come with a cigarette lighter adapter that has a regulator inline with the power connector. For the EBY701 I just cut the cigarette lighter plug off and wired it to the harness that I was using. The regulator kept it in a decent range but nothing like a computer psu. Sounds like you are fine though.
Nick - 08 GG Element
Custom 3D-CAD Design, Reverse Engineering and Fabrication
ik632 is offline   Reply With Quote
Old 07-15-2008, 03:00 PM   #6
Make sure your lighter is on a switched circuit...
Dave323Ci is offline   Reply With Quote
replacing 220V rated bulb for a 12V LED? thegingerkid General Hardware Discussion 21 04-20-2008 02:26 PM
M1-ATX and heavy 12V rail miki Power Supplies 6 05-13-2005 08:18 AM
Regulated or unregulated 12V for my display? momanz LCD/Display 14 02-09-2005 11:28 AM
Where to get regulator for cars 12v to regulated +5v 2amp? ppgt94 Power Supplies 15 08-07-2004 10:09 PM
Possible Solution for Dual Sproggy 12V @ 10A mp3z24 Power Supplies 5 07-10-2003 01:33 PM
