Old 08-14-2008, 05:42 PM   #1
Makuna is an unknown quantity at this point
Mulitple Lilliput Screens under Windows and Touch
When I read the details on the touch software that came with the 7" Lilliput screens it mentions support for mulitple monitors.
When I installed the two 7" Lilliput and touch drivers, the touch setup does imply that it should support distinct touch to each screen (it asks to touch a screen, then shows the ui on the other screen, than asks to touch again as though configuring the association of touch device and screen). But what ends up happening is that either both Touch interfaces effect the primary screen or at least once it showed touch going to the general right location BUT not consistent across the surface of each (messed up).
Has anyone every got this setup correctly?
Makuna is offline   Reply With Quote
Old 08-15-2008, 02:12 AM   #2
Hey, you're trying for the goal by going the other way around, you're crazzzyyyy!
HiJackZX1's Avatar
HiJackZX1 is just really niceHiJackZX1 is just really niceHiJackZX1 is just really niceHiJackZX1 is just really nice
I didnt use the software that came with the lilliput because I lost the CD. I went to this site, http://touchkit.com/Drivers.htm#xp. I have 3 Lilliput EBY701s and this software works perfectly. My setup is alittle awkward, so it will say I have 2 screens, but then underneath will say 3 touch panels. I dont know if this is the same lilliput uses, but I like this one and it has only caused me problems one time, but a simple reinstall fixed it.
PS: I use version 4.3.8.4207 which is the one all the way to the right side.
HiJack ZX1 CFSC
CAR PC ITEMS [35%]
INSTALL OF MULTI PC SYSTEM [35%]
BUG WORKOUT [0%]
INTERIOR MODS [45%]
HiJackZX1 Work Log
HiJackZX1 Website!
Please build up my REP.
HiJackZX1 is offline   Reply With Quote
Old 08-18-2008, 02:26 PM   #3
Unhappy
That software shows no support for USB touch devices (of which mine are). After the install it placed no shortcuts either on the desktop or in any start menus, and nothing was running. I can remove it is all. I suspect that since it didn't enumerate any touch devices (due to them being USB) it didn't finish the install correctly.
Old 08-18-2008, 07:51 PM   #4
HiJackZX1's Avatar
HUH, thats weird, it did so on mine. Only thing I did have to do is put the shortcut in the startup folder. It does not do it on its own. Other then that the software put icons on my desktop and program list area. All 3 of mine are USB also.
HiJack ZX1 CFSC
CAR PC ITEMS [35%]
BUG WORKOUT [0%]
INTERIOR MODS [45%]
HiJackZX1 Work Log
HiJackZX1 Website!
Old 08-20-2008, 05:48 PM   #5
Solved.
The default software does work, it just wasn't intuitive. When the TouchKit application is showing the two screens and in little text states to double click to use this device association, you should do this...
First, I have a mouse installed for setup, so I have to use it until the touch screens are associated.
Second, move the App to the screen of choice, then double click the virtual screen area for that screen, then move the app to the other screen and then double click the virtual screen area for that screen. Then it just works. Moveing the application was not obvious.
Old 08-21-2008, 01:49 PM   #6
HiJackZX1's Avatar
Quote: Originally Posted by Makuna View Post
Solved.
Thanx for the heads up........
HiJack ZX1 CFSC
CAR PC ITEMS [35%]
BUG WORKOUT [0%]
INTERIOR MODS [45%]
HiJackZX1 Work Log
HiJackZX1 Website!
FAQ: Touchscreens explained RedGTiVR6 The FAQ Emporium 1 07-21-2008 11:10 AM
Lilliput touch screen Help..please avn128 LCD/Display 2 08-03-2006 05:20 PM
Lilliput 7" (first model) touch function dead holistic LCD/Display 3 09-28-2005 02:27 AM
Windows not detecting Lilliput USB TS chapstick LCD/Display 3 05-02-2005 04:49 PM
Feedback Post: Owners Of Lilliput VGA Touch Screens Plz Read foneman LCD/Display 36 12-31-2004 04:37 PM
