Old 08-19-2008, 09:34 PM   #1
RyanB95's Avatar
RyanB95 is an unknown quantity at this point
Touchkit problem
Hey guys,
I'm just wondering if anyone else has had trouble with Touchkit recognizing their touchscreen being plugged into a USB port? Upon searching I found a bunch of threads regarding the touchscreen controller's functionality itself -- I don't believe that's my problem at all though, rather just getting the touchkit to recognize that my touch panel is actually plugged into the USB port. I say that the touch controller itself is not broken because I had it working last week... but I unplugged everything from it and powered the carPC down while I relocated it within the car. After I plugged everything back in, the touchscreen failed to work. Whether or not I plugged the USB back into the same port that touchkit had it assigned to I'm not sure. But since it didn't work initially after the move, I tried all other ports and have been un and re-installing the drivers ever since with no luck. Is there any sort of combination or trick to getting it to work right without thinking that the mouse I have plugged in is the touch controller (it did that once or twice)? I've tried it with the mouse plugged into a USB port and with it plugged into a PS/2 port with no luck. Any suggestions?
Thanks!
1995 AWD Tsi Talon
Intel D945GCLF
M2-ATX
2GB Corsair
30GB OCZ SSD
BU-353
Lilliput EBY-701
Logitech DiNovo Mini
LSX VOID 3.3
RyanB95 is offline   Reply With Quote
Old 08-21-2008, 05:07 PM   #2
RyanB95's Avatar
No one?
1995 AWD Tsi Talon
Intel D945GCLF
M2-ATX
2GB Corsair
30GB OCZ SSD
BU-353
Lilliput EBY-701
LSX VOID 3.3
Old 08-21-2008, 05:10 PM   #3
russoxley187 is an unknown quantity at this point
drivers?
russoxley187 is offline   Reply With Quote
Old 08-21-2008, 09:02 PM   #4
RyanB95's Avatar
I'm using the same ones that I used when I had it working before
1995 AWD Tsi Talon
Intel D945GCLF
M2-ATX
2GB Corsair
30GB OCZ SSD
BU-353
Lilliput EBY-701
LSX VOID 3.3
Old 08-21-2008, 09:08 PM   #5
pancit175 is on a distinguished road
Try reinstalling the drivers. In some cases i have seen with some USB devices, the protocol that designates the location of the device, as far as wiring through which ports or through a hub, may not have been reinitiallized when you changed the port.
For example, I have the turtle beach advantage micro usb sound-dongle. If I unplug it while shutdown, move it over one plug and restart, before I can be used again I have to reinitallize it, but I have to do it manually which they have set through the taskbar icon.
PROGRESS:
pancit175 is offline   Reply With Quote
Old 08-21-2008, 11:27 PM   #6
RyanB95's Avatar
I've tried reinstalling the drivers a few times with no luck. I feel like theres a trick to get it working with my particular setup. I guess I'm just gonna have to mess with it some more unless anyone has any other suggestions.
1995 AWD Tsi Talon
Intel D945GCLF
M2-ATX
2GB Corsair
30GB OCZ SSD
BU-353
Lilliput EBY-701
LSX VOID 3.3
gps navilock and com problem lele67 GPS 0 04-01-2006 08:41 PM
Problem with directshow filter and WMP EricE Software & Software Development 0 03-01-2006 11:38 AM
Car Idle - power/amp problem? TheFaze Car Audio 1 12-16-2005 12:10 AM
had an all day (9 hr) problem at work.... wizardPC Off Topic 13 10-20-2005 12:50 PM
Lilliput TouchKit problem solved! AAVfReaK LCD/Display 2 10-16-2004 04:51 PM
