Your video card is outputting a poor signal which the TV is having trouble holding on to. What you finding is that when its showing a colour display, the TV is actually on the aboslute borderline, and with the engine running it tips it just over the edge. Its easier to decode a luminance signal than the chrome signal, hence B&W. I had this exact problem way back with a VGA>Composite convertor, and on one TV it would go to B&W after a few minutes, then eventually lose sync altogether. The tolerances of the TV components play a part in the sensitivity.
You can simulate a similar type of thing (although its an RF signal, the principles of the actual demodulated signal apply) by detuning your home TV slightly whilst watching a standard TV broadcast. Notice how it becomes B&W long before the picture is unwatchable.
Solution, get a different TV out card for your PC.
(=========-) 99% complete
AMD K6/2 500 @ 450mhz to keep heat and power usage down, 64Mb, slim CDrom drive, 64mb USB pendrive for MP3 transfer, 10Gb 2.5" drive for MP3, USB>RS232
All jammed in external CDROM drive case.
Kenwood KVC-1000r In-Dash LCD. x-10 MouseRemote. Destinator V2 Gps. DC-DC with onboard Shutdown controller.
