Old 09-29-2008, 11:51 AM   #1
jeremy480 is an unknown quantity at this point
Lilliput 629 touch screen hibernation issue
I recently replaced an old Dynamix monitor with a Lilliput 629GL-70NP. The problem I am running into is when resuming from hibernation the touch screen portion does not work at all. My other USB devices (GPS, Keyboard, WiFi etc.) work just fine when resuming from hibernation.
I also though it was weird that I need to reboot Windows XP twice before it recognizes the touchscreen again. If I just reboot it once I still have the same problem where the touch screen does not work. I never had this issue with the Dynamix touch screen. Any idea what the problem could be?
Thanks,
SPECS:
Windows XP SP3
Intel Atom D945GCLF2 motherboard
1GB RAM
M2ATX Power Supply
Lilliput 629GL-70NP monitor
jeremy480 is offline   Reply With Quote
Old 09-29-2008, 02:28 PM   #2
Neither darque nor pervert
DarquePervert's Avatar
DarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of light
Is the touchscreen going through a USB hub by any chance?
LOOKING FOR THE FAQ? IT'S HERE.
You never found that link, did you? Why? It's hard to find in the NavBar across the top of the forums, amongst a lot of other crap.
TELL MP3CAR YOU WANT A LINK TO THE FAQ IN A MORE OBVIOUS, NOTICABLE LOCATION HERE.
Old 09-29-2008, 04:40 PM   #3
No, it is plugged into one of the four on board USB ports. I also tried relocating it to another USB port with no luck.
Also, I am using the driver on the CD included with my monitor because the download section on Lilliput's website is down.
Old 09-29-2008, 07:38 PM   #4
Look int eh FAQ Emporium. There's a thread in there with a link to the most current touchkit drivers.
That may resolve your problem.
Old 09-29-2008, 07:46 PM   #5
insaneramman's Avatar
insaneramman is an unknown quantity at this point
Smile Check this...
While touchscreen is running check system propeties goto your touchscreen make sure in the power section that the box that says allow computer to cut power(or something like that) to this device to conserve power isn't checked. I had a similar prob and this solved it. It's worth a shot if you hadn't already.
insaneramman is offline   Reply With Quote
Old 09-30-2008, 01:02 PM   #6
Well one link in the FAQ is directed to Lilliput's website which is down. The other link goes to the manufacturer of touchkit I think. Anyways, when I used the touchkit driver it didn't work at all.
I noticed this before when troubleshooting earlier. I went ahead and unchecked it as you suggested and so far so good! Granted the car has only gone into hibernation mode once but I will check it again on my lunch break and see if its working. Thanks for the tip!
Lilliput TOUCH SCREEN StOpS !!!!!!!! vicky_obee LCD/Display 22 01-07-2007 07:37 PM
Lilliput 8" touch screen backwards - FC4 DJBigShow Linux 9 08-04-2006 03:43 PM
FS: Lilliput 619gl-70np/c/t 7" touch screen kingeorge36 Classified Archive 7 05-06-2006 04:52 PM
Lilliput Touch screen Wendy Newbie 4 11-07-2005 08:48 AM
Lilliput 629 screen not clear - help gdawg LCD/Display 0 09-28-2005 09:34 AM
