Old 10-09-2008, 07:08 AM   #1
Dragonlove is an unknown quantity at this point
Touchkit is slow after standby
Hi i have a 7" lilliput and a XP based computer in my car, but then i start up Xp from standby it might take up to 1 min before i can use the touchscreen, is there any solution for this?
Dragonlove is offline   Reply With Quote
Old 01-20-2009, 08:37 PM   #2
Dougw133 is an unknown quantity at this point
Any resolution? I am noticing the same thing now, but I believe it is more USB related.
Dougw133 is offline   Reply With Quote
Old 01-20-2009, 08:41 PM   #3
Fusion Brain Creator
2k1Toaster's Avatar
2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future
Always connect your touchscreen directly to the motherboard's root USB port. Do NOT connect it to a hub, or this will happen.
Old 01-21-2009, 08:53 AM   #4
Well mine is direct to the motherboard, infact I do not have a hub, my MB has 10 onboard USB. I am using 6. I noticed the device manager "Refreshing" when it is open as well as nvidia control panel. This tells be there is a USB device conflicting, not working, or just screwed. I am going to eliminate them 1 by 1 and hopefully find the culprut.
Old 01-21-2009, 11:01 AM   #5
2k1Toaster's Avatar
You can try one of the programs that disconnect devices before hibernate and reconnect on resume. Might work.
Old 01-21-2009, 11:12 AM   #6
Machinehead's Avatar
Machinehead will become famous soon enoughMachinehead will become famous soon enough
Hibernate trigger works with both standby and hibernate.
Machinehead is offline   Reply With Quote
Old 01-21-2009, 04:14 PM   #7
I am already running Devcon for GPS... I unplugged my USB Wifi and the "refreshing" stopped..I am still having device issues though.. It seems like if one is working well the others work half a$$. I don't get it.
Turning key from ACC to Crank = Laptop will standby l00kster Power Supplies 0 11-15-2007 02:27 PM
DSATX and Standby HyperZulu Power Supplies 3 06-14-2007 05:33 PM
Standby issue - goes into standby and comes right back out ckny General MP3Car Discussion 7 03-25-2007 08:10 PM
Standby issues. Seriously confused here. maxxell General Hardware Discussion 11 04-16-2005 02:26 AM
System Standby Failed (Touchkit) Nokia6600 Newbie 4 03-18-2004 08:24 AM
