Old 10-13-2008, 02:02 AM   #1
dave89 is an unknown quantity at this point
Lilliput 629 - 2008 touchpanel not working
So i removed my screen from my dash on Thursday to do a bit of tinkering with other things, when replacing the screen and powering up the touch panel was not working, first instinct was to restart, no luck with that. So i removed the usb connector and plugged it back in again and i got a pop up window in the task bar tray stating "One of your USB devices has malfunctioned, disconnect and reconnect and try again" or something to that effect. well i'd disconnect and reconnect it, same problem.
in hardware manager, it says the same thing, the device is an "unknown device" and its status is "malfunctioning" touchkit doesn't recognize the screen nor does windows. I reinstalled touch kit, latest version, no success, checked all connections, try'd a different usb port, a port i know to be working, so it's not my ports. pulled the screen apart, ribbon cables, both screen and touch panel are all in place, but i re-seated them just in case, touch panel in tact and not damaged.....
i don't know what else to try.... perhaps its the usb controller board???? who knows...... any suggestions anyone???
Dave
dave89 is offline   Reply With Quote
Old 10-13-2008, 05:08 AM   #2
sunnyboy's Avatar
sunnyboy is an unknown quantity at this point
Dave
I've the same issue, still didn't connect directly (only through HUB) hope HUB is dead, but if HUB is still alive, I have the same questions, is it usual babyborn problem for 629?
sunnyboy is offline   Reply With Quote
Old 10-13-2008, 05:38 AM   #3
Originally it was connected through a 4 port hub, which ports still work with other devices, but tested it on other available ports on the pc and no luck.
Dave
Old 10-13-2008, 05:50 AM   #4
sunnyboy's Avatar
Dave
the same, but at the same time HDD failed to start up and I couldn't test hub and other hardware..., now waiting for SSD, after it will fix touch or hub.
Old 10-13-2008, 12:44 PM   #5
sunnyboy's Avatar
UPDATE: it was hub, I've tested touch and it's working !!!!!!!!!!!! Thanks god. Good luck Dave with you touch.
Russia, Moscow
Auto switch not working right on Lilliput 629 LED djBEER LCD/Display 4 07-31-2008 09:43 PM
lilliput 7" touchscreen part is not working. petb LCD/Display 1 01-04-2008 04:26 AM
lilliput 629 won't show windows Snortonnorton LCD/Display 5 08-25-2007 01:05 PM
Lilliput EBY-701 / 629 thumper_svx LCD/Display 5 05-16-2007 06:55 PM
Lilliput Touchscreen not working jjc319 LCD/Display 5 02-01-2004 05:37 PM
