Old 10-15-2008, 03:06 PM   #1
lanman1's Avatar
lanman1 is on a distinguished road
Lilliput vs Xwnarc Revisited
Ok with the latest 2008 versions of the touch monitors, which would you chose and why? I have heard of some reliability issues with the lilli 719s but this just may have been a vocal few.
lanman1 is offline   Reply With Quote
Old 10-15-2008, 03:56 PM   #2
Neither darque nor pervert
DarquePervert's Avatar
DarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of light
Lilliputs require regulated 12v power. Xenarcs do not.
LOOKING FOR THE FAQ? IT'S HERE.
You never found that link, did you? Why? It's hard to find in the NavBar across the top of the forums, amongst a lot of other crap.
TELL MP3CAR YOU WANT A LINK TO THE FAQ IN A MORE OBVIOUS, NOTICABLE LOCATION HERE.
Old 10-15-2008, 04:34 PM   #3
fabworks is an unknown quantity at this point
The only advantage that the Xenarc has over the Lilliput is that they have the option to auto switch to a video source, that's it.
I have used both and I use the Lilliput now since it's cheaper and it can be upgraded to be Transflective. I connect the power to my screen directly to my power supply inside the carpc, don't need anything regulated.
fabworks is offline   Reply With Quote
Old 10-15-2008, 04:50 PM   #4
lanman1's Avatar
Ok so Lillis don't have the ability to auto switch to an NTSC input for say a backup camera? That's good to know. Is there a hack to change the input via a button press or do most people do it manually?
Old 10-15-2008, 05:04 PM   #5
When the new Lillis came out, everyone stated that it was possible, but I have the screen and know for a fact that it doesn't have this feature.
What I have done to make this work is connected an ON/OFF switch to the button that switches between sources, so if I ever need the back up camera, I can switch to the source with the press of a button. It was nice when I had the Xenarc because the camera would come on and the source would be switched as soon as you put the car in reverse.
But for most people this will not matter since not that many use a backup camera.
xenarc first impressions, tried lilliput before emdzey01 LCD/Display 7 06-09-2005 07:26 PM
WTB: BROKEN Lilliput 619! masch Classified Archive 7 12-14-2004 04:58 AM
Xenarc, Lilliput, Xenarc, Lilliput, Xenarc, Lilliput, Xenarc, Lilliput, Xenarc voidunknown LCD/Display 88 09-15-2004 06:38 PM
Lilliput 7" TS into TM-701L casing install problems :( NS98GSR LCD/Display 5 04-01-2004 05:37 AM
Lilliput VGA touch panel cracked. Would DigitalWW 7" touch panel fit ? shchua LCD/Display 2 12-11-2003 11:36 PM
