Hi all.
I am in the process of completing my first ever CarPC install.
Everything is working out perfectly, except for one small issue of video interference. I can see horizontal patterns of interference on the screen. It's nothing too bad, but it's definitely visible. I searched and read a number of threads on similar problems, but I could not find anything that would help me.
The patterns kind of show when the PC is doing some work. For example, they get more intense when moving the mouse. Or when opening a GPS test application, you would see interference like every half second, when the GPS receiver was sending data.
This happened when I tested the CarPC in my house as well, so it's nothing car related. It's not related to the LCD power either, as I could see the same interference when I plugged the VGA cable in my desktop's LCD monitor, which was powered separately.
The interference did not change in any way when moving/changing the VGA cable, which makes me believe that the onboard video card is actually sending out this signal..
I uploaded a pic of my connections below. I am powering the LCD as well as a USB hub from the M2-ATX (from a 4-pin molex inside the PC). I am thinking that either the mainboard just does this or perhaps I am generating noise on the 5V line and this affects the outputs. The sound output from the mainboard is great though. I tried adding capacitors between the +12V and the m2-atx gnd lines, didn't change one thing, perhaps I should try it on the +5V line as well?
Any ideas are welcome. Thank you!!
