Old 10-24-2008, 04:16 AM   #1
VorTechs's Avatar
VorTechs is an unknown quantity at this point
Did I screw it up?
Yesterday I had my in-dash Liliput 7" powered up on my bench, forgetting how to power it up I hooked up the power from a PC PSU, 12v to 12v, grounds to grounds, and ACC to the red wire.
I powered up the PC and everything was working fine...and everything worked for hours.
Then someone nudge the bench, the ACC cable came loose and the monitor shut itself down.
Having reminded myself how the monitor should have been powered, I disconnected everything, re-connected, powered up the PC and I get nothing from the monitor. If I re-wire up the ACC cable, I get the clock show on the built-in LED display, but the monitor won't flip up and the power light isn't lit up.
Is it a goner?
KimmyBean> Stu, you know that cybersex we had?
KimmyBean> I'm pregnant!
VorTechs is offline   Reply With Quote
2006 Ford F150 Screw 4x4 Truck - JAPEELER japeeler Worklogs 20 12-02-2008 03:45 PM
I Have Metal Sheets - How do I Add Screw Holes ccsnet Fabrication 36 04-30-2006 06:40 PM
how I can take out this screw ? shinjetko LCD/Display 4 04-25-2006 09:34 AM
Recommend using Set Screw Power Rings? matt11601 General Hardware Discussion 2 03-13-2006 11:36 PM
Screw the Screw the old 'so cal meet' Thread!! Date Set 7/16/05 12Vsystems MP3Car Gatherings 156 07-25-2005 12:35 PM
