Old 12-01-2008, 08:42 PM   #1
Dougw133 is an unknown quantity at this point
Clean power for my lilli>?
I have lilliput 7" that I have been running off an M2-ATX supply for a year now. he power has seemed to work fine and has been clean without any screen distortion or lines. Recently after having GPS issues I disabled the "Turn USB hub off" in Device manager to solve the GPS problem. Now it would seem the M2-ATX is under more load/draw and the screen is starting to get lines and bounce occasionally. I originally had the screen running off the 12v switched for my vehicle but that was messy too. Any good solutions or separate devices I could use to give good regulated power to my screen? Should i upgrade the PSU? Thanks...
Dougw133 is offline   Reply With Quote
Old 12-04-2008, 06:47 PM   #2
Guess not
Old 12-05-2008, 01:46 AM   #3
FPeter's Avatar
FPeter is an unknown quantity at this point
if 1A is enough, LM2941 low-drop voltage regulator is your friend!
drive a dedicated power cable (with fuse!) from the battery for the supply, put a 1-2-5-10K uF condensator after it, and this will solve the noise and power problems! you can turn on and off the supply with an optocoupler, driving it with any 5-12V line of the carpc supply
Intel D201GLY, 512MB DDR2, Samsung SP1213N 3.5" 120/7200/8M HDD, audio through digital line
bye bye noise - the DIY S/PDIF DAC
FPeter is offline   Reply With Quote
USB Syncroized 5V@8A power supply POL. Now Taking Orders!!! Beehphy User Innovations 110 06-23-2009 04:22 PM
Finalizing Power Supply Options Nstyle Power Supplies 2 04-01-2007 04:40 PM
N00b Power Question jamiewhittingha Power Supplies 15 03-25-2005 01:08 AM
FS For Sale 7" LCD VGA/USB, Opus 125w Power Supply, ATX P3-700 10GB 256r oudis Classified Archive 7 06-15-2004 10:29 PM
Install coming up... but Power questions technopsych Power Supplies 2 04-14-2004 08:16 PM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
