Old 01-22-2009, 10:24 PM   #1
diggla is an unknown quantity at this point
has anyone experienced this
This is what my screen has been doing in the morning and when I get in after work. After a few minutes its fine till I guess it gets cold.
<embed width="448" height="361" type="application/x-shockwave-flash" wmode="transparent" src="http://i24.photobucket.com/player.swf?file=http://vid24.photobucket.com/albums/c31/drewburg/0122090650.flv">
diggla is offline   Reply With Quote
Old 01-23-2009, 03:29 PM   #2
Slate is an unknown quantity at this point
Wow. it's probably the camera, but it sounds like your subs are cranked so loud they are distorting. Does the screen do the same thing when you don't have music playing?
Slate is offline   Reply With Quote
Old 01-23-2009, 08:05 PM   #3
yes even when there is no music playing, the subs are ok. maybe a little underpowered lol.
Old 01-23-2009, 09:22 PM   #4
mayhembdm666's Avatar
mayhembdm666 is an unknown quantity at this point
Does it change with the engine revs, I would think a bad grounding other wise screen fault. Have you tried the video feed into another display?
D&I Office Technology
Vehicle -: VP Commodore 1992 -Auto
CPU/Board -: 800Mhz EPIA-V (Bare Min Req)
Memory -: 512Mb SDRAM (Bare Min Req)
Screen -: 7in Voxson TFT
OS -: Windows XP SP3
Front End -: Auto Meda v4 (My Own App)
mayhembdm666 is offline   Reply With Quote
Old 01-29-2009, 04:25 PM   #5
After ordering a replacement monitor, went with a lilliput 629 shipped for $239. I decided to take apart the old monitor. Connected the power wire and moved some stuff around and found a lose connection with the ribbon cable. Taped it on after looking at how poorly designed the clamp holds it on. Here is the problem part.
Old 01-29-2009, 04:28 PM   #6
Got the new monitor, its a little taller and not as wide as the old one. Go to put it in the dash and its to tall. Cant move anything around so I decided to take both apart and see if I can switch the insides. For the most part all the holes lined up on the board except about 3 screws. Board is in securely so we will see how it holds up. The old monitor is model 701, new one is 629.
Need an experienced opinion or two on 20x... ForestCat GPS 1 08-14-2008 07:23 PM
For you experienced users, which In Dash 7 inch Touch Screen do you recomend? xenium LCD/Display 1 09-02-2007 11:49 PM
Has anyone else experienced this bug? AllShowNoGo Mobile Impact 2 12-26-2006 02:37 AM
Any experienced installers around MD/VA/DC area? narcisis General MP3Car Discussion 2 05-16-2006 09:12 AM
Experienced PC guys needs Car Audio Primer SwapMeet Newbie 6 02-10-2004 05:33 PM
