Old 01-29-2009, 01:39 AM   #1
aznd000d is an unknown quantity at this point
Question [lilliput] what plug is this?
Can anyone tell me what the black plug is?
It's from the EBY701 model.
I bought this used and it didn't come with a manual.
Thanks.
aznd000d is offline   Reply With Quote
Advertisement Sponsored links
Old 01-29-2009, 02:00 AM   #2
Fusion Brain Creator
2k1Toaster's Avatar
2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future
Thanks.
There should be RCA (yellow/red/white) and then the VGA signal and maybe an svideo depending on sub-model.
On mine the black cable is bigger and another cable screws into it with the ends for all the sources.
Old 01-29-2009, 02:03 AM   #3
That black cable you're talking about is different. I have that one too.
It's definitely not an Svideo plug.
Old 01-29-2009, 02:07 AM   #4
2k1Toaster's Avatar
Oh ok looking back at the picture (it is hard to tell because it is such low quality...) but that is the DC jack.
+12v regulated
Old 01-29-2009, 11:21 AM   #5
So there's an AC jack AND a DC jack??
Sorry for the low quality pic. It's a phone cam in bad lighting.
I'll try to get better pictures later.
Old 01-29-2009, 11:23 AM   #6
2k1Toaster's Avatar
There is no AC jack. The monitor takes DC only. The AC wall adapter spits out a DC voltage that uses that jack.
Old 01-29-2009, 11:34 AM   #7
si_romin is an unknown quantity at this point
that's the DC 12V power connection. I have an EBY701 and that's where the power goes. nice little monitor!
si_romin is offline   Reply With Quote
Old 01-31-2009, 11:56 AM   #8
alright, here are some better pictures.
this picture shows the bundle of cables hanging from the back of the monitor
this picture shows the power connector plugged straight onto the board.
So they made two connections for power?
Old 01-31-2009, 12:29 PM   #9
Deric's Avatar
Deric is an unknown quantity at this point
My Lilliput manual says (not the 701 by the way)
"Black: RCA for DC12V Input"
"White: SVideo Input"
"Yellow: RCA for Video1 input"
"White: RCA for audio input"
"Red: RCA for video 2 input"
Deric is offline   Reply With Quote
Old 01-31-2009, 01:08 PM   #10
Slate is an unknown quantity at this point
Yep, apparently some lilliput models have two power connectors. I have no idea why, but my 629GL is the exact same way. Since I have mine mounted in the dash, I just use the one on the cable.
Slate is offline   Reply With Quote
Old 01-31-2009, 01:21 PM   #11
Hey, you're trying for the goal by going the other way around, you're crazzzyyyy!
HiJackZX1's Avatar
HiJackZX1 is just really niceHiJackZX1 is just really niceHiJackZX1 is just really niceHiJackZX1 is just really nice
The EBY701 does have 2 power jacks... On 3 of my EBY701s I use the black one that hangs off, but on the 4th it was more convenient to use the power port on the screen. I like having the option. The one on the cable tends to fall out easily if you have to work with it in tight places.
HiJack ZX1 CFSC
CAR PC ITEMS [35%]
INSTALL OF MULTI PC SYSTEM [35%]
BUG WORKOUT [0%]
INTERIOR MODS [45%]
HiJackZX1 Work Log
HiJackZX1 Website!
Please build up my REP.
HiJackZX1 is offline   Reply With Quote
Old 02-03-2009, 09:37 PM   #12
thanks fellas!!!
Alright new question but no pics.
I have a cable; one end looks like a headphone plug and the other end is some sort of an IR sensor. And it's very long; I'd say about 10ft.
Old 02-04-2009, 02:33 AM   #13
adding a couple pics for the above question: "I have a cable; one end looks like a headphone plug and the other end is some sort of an IR sensor. And it's very long; I'd say about 10ft."
Old 02-04-2009, 02:37 AM   #14
2k1Toaster's Avatar
Yeah it is an IR device. By itself it is useless. It should not have come with the screen, maybe with the PC.
Plug and play but where AJWatU LCD/Display 4 10-19-2007 05:39 PM
USB plug hard wired to glovebox sky_lennard Power Supplies 5 09-30-2007 12:52 AM
Where to Buy 3 Contact DC Power Plug tallyman General MP3Car Discussion 0 03-18-2007 10:53 PM
EPIA MII 10000 onboard USB plug help guizai General Hardware Discussion 5 01-26-2007 07:08 PM
multiple items on 1 12v accessory plug... also where to find dc-dc supply Valhalla1 Power Supplies 5 07-12-2003 02:43 AM
