Old 01-31-2009, 02:44 PM   #1
smithjames0 is an unknown quantity at this point
Lilliput problems
Hi I need some help regarding my 7" Lillput touch screen. The problem is I carn't 'touch' the bottom left hand corner of the screen. I have calabrated the screen loads of times, but I still have the problem. I have Draw tested the screen and when i draw a straight line from the top left to the bottom left I get this.
Can anyone help?
James
smithjames0 is offline   Reply With Quote
Old 01-31-2009, 03:08 PM   #2
Super Moderator & Wal-Mart Greeter
Tidder's Avatar
Tidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant future
That's odd. Is it still under warranty? Sounds like the touch panel needs replaced. Also did you go thru the advanced point calibration? It has something like 16 points... I can't recall off the top of my head.
Tidder
Try RevFE
The best frontend I've ever used, period.
Best Quote EVER!!
Quote: Originally Posted by bramlet View Post
I try to search but I usually only find posts where people ask questions and darquepervert tells them to search.
Tidder is offline   Reply With Quote
Old 01-31-2009, 03:36 PM   #3
I have only done the four point calibration. The monitor is second had, the thing is if I touch there, the mouse still works just not under your finger.
James
Old 01-31-2009, 04:09 PM   #4
Tidder's Avatar
Try doing the extra calibration just to see... that's odd... could be panel or controller, hard to say. Also, has it been taken apart? You may want to try the touch with the front bezel off, it could be pushing or tweaking something.
Tidder
Try RevFE
Best Quote EVER!!
Old 02-01-2009, 02:28 PM   #5
Thanks to all I did the advance calabration and it sorted it!
James
Old 02-01-2009, 07:12 PM   #6
blackcobra487 is an unknown quantity at this point
Yeah, that's something that people should make note of. Do the higher point calibration, it works so much better. If that's not in the FAQ, it should be.
03 Accord Sedan CarPC
blackcobra487 is offline   Reply With Quote
Lilliput 7" EBY701 Problems - Not working? hatchback19 LCD/Display 4 04-24-2008 04:11 PM
Lilliput FA841, 14 Pin Centronics pinout (verify plz) and several problems h3rk LCD/Display 1 04-13-2008 05:05 PM
MacMini problems with Lilliput simmo MacCar 12 11-07-2007 11:06 PM
EPIA M10000 + Lilliput 619 problems Calipso General Hardware Discussion 4 04-04-2007 09:42 PM
Lilliput and ribbon cable problems Udonboy LCD/Display 21 11-08-2004 08:24 PM
