Old 02-09-2009, 09:30 AM   #1
_Dejan_'s Avatar
_Dejan_ is an unknown quantity at this point
8" LCD touchscreen with LED backlight
Hi,
Im looking for new 8" LCD because my 1 year old CTF-800 is TOO HOT and have big problems when outside is little colder wearther(-5°C)
What Im looking:
-Size: 8" touchscreen
-If is possible then I would like have widescreen(16:9)
-LED backlight (Because is colder than normal)
-It can be TMR or transreflective but is not so important
-Operating temperature from -10°C(can be lower too -20°C) to 50°C or more
-Can be open frame or in normal case
So can someone help me with right choise?
Thanks.
Regards, _Dejan_
_Dejan_ is offline   Reply With Quote
Old 02-09-2009, 03:25 PM   #2
Maheriano will become famous soon enoughMaheriano will become famous soon enough
The Xenarc 700TSV CCFL does all that so I assume the LED version they have would work better.
Ampie Case
256 MB DDR2 PC5400
Xenarc 700TSV - VGA Monitor
Intel D945GCLF Motherboard
M2-ATX-HV
2005 Honda Civic
Maheriano is offline   Reply With Quote
Old 02-09-2009, 04:36 PM   #3
SoulR's Avatar
SoulR is an unknown quantity at this point
There is meant to be a LED 8" Lilliput on the market too now maybe an option.
SoulR is offline   Reply With Quote
Old 02-09-2009, 05:09 PM   #4
_Dejan_'s Avatar
Please read again my post.
-This LCD is 7" I looking for 8"
-Operating Temperature: 23°F ~ 158°F = -5°C ~ 70°C I need that work in lower temperatures.
-do not use LED backlight
Do you know which model?
For now Im find next one but I don't know If is all data real...
LinITX 8"
Old 02-09-2009, 05:42 PM   #5
My mistake, I thought they offered it in 8.
It does. I have it. And I bet the cost of your new carputer that it gets colder here than it does in Slovenia.
The 705TSV does, should work in the same temperatures.
Ampie Case
256 MB DDR2 PC5400
M2-ATX-HV
2005 Honda Civic
Old 02-09-2009, 05:51 PM   #6
_Dejan_'s Avatar
"should work in the same temperatures" doesn't mean nothing. Why? If LCD will not turn on when outside temp will be -10 or -20°C what can I do? I can't return LCD because they are write that work from -5°C to 70°C...
I have CTF-800 and it doesn't work below 0°C(light just flashing) and I can't do nothing because in manual write that work from 0°C to 50°C...
So Im loking for LCD where manufacturer "provide" me that will work at -10°C or beter -20°C...
BTW 705TSV is 7"
Old 02-09-2009, 09:40 PM   #7
SoulR's Avatar
The 8" Lilliput model is 889GL-80NP/C/T, you will see them on ebay stating they now have a LCD backlight instead of CCF (it's widescreen format like the CTF-800).
Old 02-10-2009, 01:29 AM   #8
_Dejan_'s Avatar
Im find this model and look very nice and is very cheap.
Bout I can't find anywheere in which range normaly work...
Im contact lilliput for this data and I waiting for response...
Thanks.
Regards, _Dejan_
Old 02-10-2009, 07:10 AM   #9
_Dejan_'s Avatar
Im receive answer from lilliput:
Our item 889gl-80npct (8" 16:9 lcd vga touchscreen pc monitor,if you need the 8" 4:3,you can choose 859gl-80npct) the operating temperature will be -15 °C t0 60°C,( but the -20°C -70 °C is Critical point).
So I think 889gl-80npct is right choise for me
Old 02-13-2009, 02:57 PM   #10
Good luck. However after reading these forums for 3 years, I've seen many more complaints about the Lilliputs not turning on in even mild temperatures where my Xenarc and many like mine work in temperatures 40-50 below. I just hope it works out for you, maybe the newer technology fixed this.
Ampie Case
256 MB DDR2 PC5400
M2-ATX-HV
2005 Honda Civic
Old 02-14-2009, 10:11 AM   #11
mohamedali21 is an unknown quantity at this point
I had this monitor (CTF800). It was selling my mp3car a few years ago and the touchscreen gives too much problem. needs to calibreate everytime....I would NOT recommend this monitor to anyone...I use this http://dynamixcomputers.com/dynamix_...n_monitor.html and didn't have any problem since.
mohamedali21 is offline   Reply With Quote
Old 02-14-2009, 04:11 PM   #12
_Dejan_'s Avatar
Sory but it doesn't have LED backlight and operating temperature is from 20°C to 70°C
FAQ: LCD Technologies dontpntpool LCD/Display 4 03-15-2007 01:20 AM
WTB: 8" with or without touchscreen LCD mmdb Classified Archive 1 10-29-2005 05:44 PM
Xenarc 800TSV 8" TFT LCD /w Touchscreen - Brushed Aluminum RedGTiVR6 LCD/Display 41 03-08-2005 07:17 AM
